double tap 1 and 2 finger tap on Left, Right, Middle (edge)
I use a single tap or corner click for window management on the main screen, whereas for the secondary screen it’s easier to use the same gesture by simply adding a finger. Triple tap would be nice if it possible.
you can use the default "double tap" gestures in BTT and limit their triggering to the edges via "advanced trigger conditions". Here is an example for a double-tap that only works on the left 10% of the trackpad:
it works, thanks you! but for the rightmost is less then 10% did not, i have to changed it into leftmost is greater than 90%. but a preset will be better, like corner double tab, middle top double tab, etc.
