I am trying to set up a touch gesture to zoom in and out in Photoshop using the Magic Trackpad 2. For example, a 3 finger swipe down zooms in and a 3 finger swipe up zooms out. How can I set up this gesture using the BTT configurator?
Yes, that works and produces an incremental zoom in/out effect requiring repeated gestures to achieve a specific zoom level.
In OSX disabling the Show Spotlight search shortcut in System Preferences, allows Photoshop to use the Cmd+Spaceabr short cut to execute a fluid zoom in/out with the mouse.
The action is as follow:
With a Photoshop document open press Cmd+Spacebar, then press and hold mouse, drag left to zoom out and drag right to zoom in.
Can BTT perform this fluid zoom behavior in Photoshop? I am unable to set this action in BTT.
The screenshots show the System Preferences pane and BTT configurator settings.
