I have got TipTap 1 finger fix set up for left and right click. I rest my fingers on the mouse and when I click the left or right mouse button I have to take my finger off of the mouse for a little while and then click. If I click normally it doesn’t register because I do it too quick. I have changed all of the settings to have a 0 second delay but this still doesn’t work.
Can someone help or is there a way to change the advanced configurations on this?
Unfortunately I don't think the tip taps are suited for this.
The logic that requires you to lift the finger is necessary because otherwise the tiptaps would constantly trigger accidentally, e.g. when starting a two finger scroll. I have done tons of experiments with this, but couldn't find a better solution than the current.
I'm sure there would be ways to make that work, but I was not able to do it. It always lead to tons of false positive triggers. For your usage I'd get a different mouse.
