Magic Mouse left tap acts like right tap sometimes
This problem has persisted across several versions over the past couple years.
On my magic mouse, I have set left tap to be left click, and right tap to be right click.
Usually it works well. However, if I walk away from my computer for about ten minutes or so, when I start using my mouse again, the left tap acts like a right tap (right tap works normally).
My screen savers are set to trigger after 15 minutes, and my computers to sleep after 30 minutes or more, so it is not related to screen saver or sleep.
Magic Mouse
  • Type of Mac:
    Macbook Pro 2017 15 inch w/ touchbar (Catalina)
    Macbook Pro M1 16inch (Monterey)
  • BetterTouchTool version: 4.062 (2278)
I think this might be one of the oldest bugs in BTT (the faulty code was added in 2010), but your description with the screen saver and sleep timings helped me to finally locate it!
Will be fixed with the next version soon.
Amazing, that would eliminate years of frustration, thank you!
