So I want to have a key sequence triggered with Magic Mouse Double Tap.
Currently, I have the key sequence as Command + W (close window) but this is temporary as I have a different key sequence I want to use but was testing with this simple one first.
But when I double tap on Magic Mouse, even though I have HUD confirmation of Key Sequence being triggered, it does not actually close any current window with the Command + W key sequence.
But my issue with using keyboard shortcuts is that it won't work with just a combination of modifier keys.
My real use of Double Tap on Magic Mouse is to trigger something like Option + Tab. But since both of these are modifier keys, I cannot use the keyboard shortcuts. Is there any other way?
tab is not a modifier key (only shift (& capslock), cmd, ctrl, opt and fn are). If you really need to just trigger modifier keys you can use the dedicated actions for these:
Ah, so with dedicated actions I could have a combination of Option Down, Command Down, Option Up, Command Up and it would act like if I pressed Option + Command and let go?
