BetterTouchTool_2019-06-12-165640_NoimSKBook.crash (91.3 KB)
this seems to be a macOS issue - it's still working fine here. I'd try to re-download BTT via https://folivora.ai/downloads
@Andreas_Hegenberg Is there a way that a button can "show always" regardless of modifier keys, but have BTT check so that if the icon is set to nothing, then hide it? Right now, it will show an empty button when the icon is invisible.
If that would be possible, I could have custom applescripts that check not only for a wide range of modifier key combinations, but they could also factor in other variables (e.g. if music is playing, if an application is at the front) and then show/hide BTT touch bar buttons accordingly. Perhaps this is already a feature, but it is just buggy on 10.15?
I noticed that trackpad swipes are very sluggish on Catalina (3.084/1191). I have three finger up/down for volume and four fingers for brightness. It used to work snappy on Mojave.
Hm - it's working perfectly for me on Beta 2. Any other factors you can think of? I'm on a 2018 15" MBP. You?
2017 13'' MBP; 3,1GHz i5. Right now it works ok-ish again... I'm trying to figure out what processes are running when the sluggishness occurs. I had a runaway "icloud" process; maybe that had something to do with it?
Fingers crossed that that was the problem!
Catalina beta 2
BTT (latest alpha) and the new Config tool used to work well
Now the new Config tool crashes upon launch
Application Specific Information: Crashing on exception: -[NSFlippableView(0x7f94efd527e0) lockFocus] failed with window=0x0, windowNumber=0, [self isHiddenOrHasHiddenAncestor]=0
Old Config tool works
I observed increasingly sluggish BTT UI responsiveness adding more mouse gesture recognizers and named events. Not sure if relevant to crash.
Running quite a few other customization apps:
- Karabiner
- Only for remap of
Caps_Lockto r_cmd+r_alt+r_shift+r_ctrl) - btw in the old config there is a UI bug when you turn on to differentiate between right or left modifier keys and then assign via the Hyper key (all four on right side); it is displayed as
r^.
- Only for remap of
- PopClip
- Hazel
- Alfred
- Copied
- Bartender
- ScreenFloat
- Yoink.
Console.app output
Console.app outputs these, at a rate of up to 10-20-30/second:
default 18:29:19.277479+0200 apsd <APSCourier: 0x7fac99406cb0>: Rescheduling request to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier ""
default 18:29:19.353100+0200 apsd <APSCourier: 0x7fac99406cb0>: Received request from <APSConnectionServer: 0x7fac9910d9a0> to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier ""
default 18:29:19.353935+0200 apsd <APSCourier: 0x7fac99406cb0>: Received request to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier "", assigned appId "0"
default 18:29:19.353951+0200 apsd <APSCourier: 0x7fac99406cb0>: Rescheduling request to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier ""
default 18:29:19.484786+0200 apsd <APSCourier: 0x7fac99406cb0>: Received request from <APSConnectionServer: 0x7fac9910d9a0> to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier ""
default 18:29:19.485676+0200 apsd <APSCourier: 0x7fac99406cb0>: Received request to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier "", assigned appId "0"
default 18:29:19.485693+0200 apsd <APSCourier: 0x7fac99406cb0>: Rescheduling request to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier ""
default 18:29:21.212476+0200 apsd <APSCourier: 0x7fac99406cb0>: Received request from <APSConnectionServer: 0x7fac9910d9a0> to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier ""
default 18:29:21.213386+0200 apsd <APSCourier: 0x7fac99406cb0>: Received request to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier "", assigned appId "0"
default 18:29:21.213401+0200 apsd <APSCourier: 0x7fac99406cb0>: Rescheduling request to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier ""
default 18:29:21.403318+0200 apsd <APSCourier: 0x7fac99406cb0>: Received request from <APSConnectionServer: 0x7fac9910d9a0> to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier ""
default 18:29:21.404167+0200 apsd <APSCourier: 0x7fac99406cb0>: Received request to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier "", assigned appId "0"
default 18:29:21.404185+0200 apsd <APSCourier: 0x7fac99406cb0>: Rescheduling request to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier ""
default 18:29:21.485379+0200 apsd <APSCourier: 0x7fac99406cb0>: Received request from <APSConnectionServer: 0x7fac9910d9a0> to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier ""
default 18:29:21.486222+0200 apsd <APSCourier: 0x7fac99406cb0>: Received request to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier "", assigned appId "0"
default 18:29:21.486241+0200 apsd <APSCourier: 0x7fac99406cb0>: Rescheduling request to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier ""
default 18:29:21.578042+0200 apsd <APSCourier: 0x7fac99406cb0>: Received request from <APSConnectionServer: 0x7fac9910d9a0> to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier ""
default 18:29:21.579070+0200 apsd <APSCourier: 0x7fac99406cb0>: Received request to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier "", assigned appId "0"
default 18:29:21.579088+0200 apsd <APSCourier: 0x7fac99406cb0>: Rescheduling request to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier ""
default 18:29:21.630243+0200 apsd <APSCourier: 0x7fac99406cb0>: Received request from <APSConnectionServer: 0x7fac9910d9a0> to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier ""
default 18:29:21.631215+0200 apsd <APSCourier: 0x7fac99406cb0>: Received request to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier "", assigned appId "0"
default 18:29:21.631249+0200 apsd <APSCourier: 0x7fac99406cb0>: Rescheduling request to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier ""
default 18:29:21.962383+0200 apsd <APSCourier: 0x7fac99406cb0>: Received request to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier "", assigned appId "0"
default 18:29:21.962404+0200 apsd <APSCourier: 0x7fac99406cb0>: Rescheduling request to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier ""
default 18:29:22.343260+0200 apsd <APSCourier: 0x7fac99406cb0>: Received request from <APSConnectionServer: 0x7fac9910d9a0> to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier ""
default 18:29:22.344125+0200 apsd <APSCourier: 0x7fac99406cb0>: Received request to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier "", assigned appId "0"
default 18:29:22.344141+0200 apsd <APSCourier: 0x7fac99406cb0>: Rescheduling request to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier ""
default 18:29:22.491079+0200 apsd <APSCourier: 0x7fac99406cb0>: Received request from <APSConnectionServer: 0x7fac9910d9a0> to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier ""
default 18:29:22.491924+0200 apsd <APSCourier: 0x7fac99406cb0>: Received request to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier "", assigned appId "0"
default 18:29:22.491940+0200 apsd <APSCourier: 0x7fac99406cb0>: Rescheduling request to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier ""
default 18:29:22.560183+0200 apsd <APSCourier: 0x7fac99406cb0>: Received request to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier "", assigned appId "0"
default 18:29:22.560199+0200 apsd <APSCourier: 0x7fac99406cb0>: Rescheduling request to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier ""
default 18:29:22.693114+0200 apsd <APSCourier: 0x7fac99406cb0>: Received request from <APSConnectionServer: 0x7fac9910d9a0> to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier ""
default 18:29:22.693969+0200 apsd <APSCourier: 0x7fac99406cb0>: Received request to generate token for topic "com.apple.icloud-container.clouddocs.iCloud.com.hegenberg.BetterTouchTool" and identifier "", assigned appId "0"
Latest backtrace
Process: BetterTouchTool [44899]
Path: /Applications/BetterTouchTool.app/Contents/MacOS/BetterTouchTool
Identifier: com.hegenberg.BetterTouchTool
Version: 3.097 (1204)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: BetterTouchTool [44899]
User ID: 501
Date/Time: 2019-06-29 01:18:57.156 +0200
OS Version: Mac OS X 10.15 (19A487l)
Report Version: 12
Bridge OS Version: 4.0 (17P50482j)
Anonymous UUID: 5F70E9E0-136C-1590-8F8E-44E851E9187B
Sleep/Wake UUID: 58BE8D00-F93D-46F4-A9E5-7749CF7B604E
Time Awake Since Boot: 25000 seconds
Time Since Wake: 8600 seconds
System Integrity Protection: disabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_INSTRUCTION (SIGILL)
Exception Codes: 0x0000000000000001, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Illegal instruction: 4
Termination Reason: Namespace SIGNAL, Code 0x4
Terminating Process: exc handler [44899]
Application Specific Backtrace 1:
0 CoreFoundation 0x00007fff3d259063 __exceptionPreprocess + 250
1 libobjc.A.dylib 0x00007fff729da06b objc_exception_throw + 48
2 CoreFoundation 0x00007fff3d274944 +[NSException raise:format:arguments:] + 88
3 Foundation 0x00007fff3f968c41 -[NSAssertionHandler handleFailureInMethod:object:file:lineNumber:description:] + 191
4 AppKit 0x00007fff3a5aa858 -[NSView lockFocus] + 234
5 UIFoundation 0x00007fff6d342098 -[NSLineFragmentRenderingContext drawAtPoint:inContext:] + 3029
6 UIFoundation 0x00007fff6d3214d8 __NSStringDrawingEngine + 9132
7 UIFoundation 0x00007fff6d335d55 _NSStringDrawingCore + 173
8 AppKit 0x00007fff3a78bcda _NSDrawTextCell + 3700
9 AppKit 0x00007fff3a5ba58e __45-[NSTextFieldCell _drawForegroundOfTextLayer]_block_invoke + 76
10 AppKit 0x00007fff3a53d7ac -[NSFocusStack performWithFocusView:inWindow:usingBlock:] + 92
11 AppKit 0x00007fff3a5b9e7c -[NSTextFieldCell drawForegroundOfTextLayer] + 286
12 AppKit 0x00007fff3af6de2b NSTextLayerDrawForeground + 167
13 QuartzCore 0x00007fff48cb384c CABackingStoreUpdate + 577
14 QuartzCore 0x00007fff48d0a9c5 ___ZN2CA5Layer8display_Ev_block_invoke + 53
15 QuartzCore 0x00007fff48cb2b77 -[CALayer _display] + 2090
16 AppKit 0x00007fff3a5b9445 __22-[NSTextLayer display]_block_invoke + 690
17 AppKit 0x00007fff3a4db4f5 +[NSAppearance _performWithCurrentAppearance:usingBlock:] + 66
18 AppKit 0x00007fff3a5b8d7a -[NSTextLayer display] + 368
19 QuartzCore 0x00007fff48cb1fa5 _ZN2CA5Layer17display_if_neededEPNS_11TransactionE + 739
20 QuartzCore 0x00007fff48dd5bca _ZN2CA7Context18commit_transactionEPNS_11TransactionEd + 342
21 QuartzCore 0x00007fff48ca1072 _ZN2CA11Transaction6commitEv + 638
22 AppKit 0x00007fff3ad65bfa __62+[CATransaction(NSCATransaction) NS_setFlushesWithDisplayLink]_block_invoke + 266
23 AppKit 0x00007fff3ad66022 ___NSRunLoopObserverCreateWithHandler_block_invoke + 41
24 CoreFoundation 0x00007fff3d204468 CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION + 23
25 CoreFoundation 0x00007fff3d204392 __CFRunLoopDoObservers + 457
26 CoreFoundation 0x00007fff3d1a7349 __CFRunLoopRun + 1219
27 CoreFoundation 0x00007fff3d1a6c01 CFRunLoopRunSpecific + 499
28 HIToolbox 0x00007fff3bddd53d RunCurrentEventLoopInMode + 292
29 HIToolbox 0x00007fff3bddd27d ReceiveNextEventCommon + 600
30 HIToolbox 0x00007fff3bddd007 _BlockUntilNextEventMatchingListInModeWithFilter + 64
31 AppKit 0x00007fff3a4af804 _DPSNextEvent + 990
32 AppKit 0x00007fff3a4ae577 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1352
33 AppKit 0x00007fff3a4a8cc7 -[NSApplication run] + 658
34 AppKit 0x00007fff3a49ab9b NSApplicationMain + 777
35 libdyld.dylib 0x00007fff73d643f9 start + 1
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.apple.AppKit 0x00007fff3a8617a7 -[NSApplication _crashOnException:] + 106
1 com.apple.AppKit 0x00007fff3ad65e15 __62+[CATransaction(NSCATransaction) NS_setFlushesWithDisplayLink]_block_invoke + 805
2 com.apple.AppKit 0x00007fff3ad66022 ___NSRunLoopObserverCreateWithHandler_block_invoke + 41
3 com.apple.CoreFoundation 0x00007fff3d204468 CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION + 23
4 com.apple.CoreFoundation 0x00007fff3d204392 __CFRunLoopDoObservers + 457
5 com.apple.CoreFoundation 0x00007fff3d1a7349 __CFRunLoopRun + 1219
6 com.apple.CoreFoundation 0x00007fff3d1a6c01 CFRunLoopRunSpecific + 499
7 com.apple.HIToolbox 0x00007fff3bddd53d RunCurrentEventLoopInMode + 292
8 com.apple.HIToolbox 0x00007fff3bddd27d ReceiveNextEventCommon + 600
9 com.apple.HIToolbox 0x00007fff3bddd007 _BlockUntilNextEventMatchingListInModeWithFilter + 64
10 com.apple.AppKit 0x00007fff3a4af804 _DPSNextEvent + 990
11 com.apple.AppKit 0x00007fff3a4ae577 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1352
12 com.apple.AppKit 0x00007fff3a4a8cc7 -[NSApplication run] + 658
13 com.apple.AppKit 0x00007fff3a49ab9b NSApplicationMain + 777
14 libdyld.dylib 0x00007fff73d643f9 start + 1
Thread 1:
0 libsystem_pthread.dylib 0x00007fff73f6c68c start_wqthread + 0
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x00007fff73eac286 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff73eac7ec mach_msg + 60
2 com.apple.CoreFoundation 0x00007fff3d1a7f95 __CFRunLoopServiceMachPort + 322
3 com.apple.CoreFoundation 0x00007fff3d1a7525 __CFRunLoopRun + 1695
4 com.apple.CoreFoundation 0x00007fff3d1a6c01 CFRunLoopRunSpecific + 499
5 com.apple.AppKit 0x00007fff3a4b6ce2 _NSEventThread + 132
6 libsystem_pthread.dylib 0x00007fff73f6fdaa _pthread_start + 125
7 libsystem_pthread.dylib 0x00007fff73f6c6af thread_start + 15
Thread 14:
Thread 15:
Thread 16:
Thread 17:
Thread 18:
Thread 19:
Thread 20:
Thread 21:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x00007f94f800e000 rbx: 0x00006000031699e0 rcx: 0x9916fcf93a20008a rdx: 0x0000000000000000
rdi: 0x0000600003169710 rsi: 0x0000000000000e45 rbp: 0x00007ffee89e03a0 rsp: 0x00007ffee89e0390
r8: 0x0000000000000045 r9: 0x00007f94f800ee45 r10: 0x0000000000000045 r11: 0x0000000000000000
r12: 0x00007f9508006048 r13: 0x0000000000000002 r14: 0x00007fff729cdd40 r15: 0x0000600000f3e440
rip: 0x00007fff3a8617a7 rfl: 0x0000000000010206 cr2: 0x0000600000c59000
Logical CPU: 8
Error Code: 0x00000000
Trap Number: 6
Binary Images:
0x10721e000 - 0x107a20ff7 +com.hegenberg.BetterTouchTool (3.097 - 1204) <0AAC8D2C-E439-324E-87B5-48C5DE570A72> /Applications/BetterTouchTool.app/Contents/MacOS/BetterTouchTool
0x10863d000 - 0x1086c0ff7 +com.mixedinkey.MIKMIDI (1.5 - 877) <5CE361C9-9E8D-37E9-B022-24BFF71F12A2> /Applications/BetterTouchTool.app/Contents/Frameworks/MIKMIDI.framework/Versions/A/MIKMIDI
0x108709000 - 0x10874bfff +org.sparkle-project.Sparkle (1.18.1 14071-g6b01db6f4 - 1.18.1) <1522A52C-5418-3863-816B-BED4C543E67E> /Applications/BetterTouchTool.app/Contents/Frameworks/Sparkle.framework/Versions/A/Sparkle
0x108775000 - 0x108784ff7 +net.wafflesoftware.ShortcutRecorder.framework.Leopard (1.0) <63542887-8F80-387F-A49B-90D3D630F667> /Applications/BetterTouchTool.app/Contents/Frameworks/ShortcutRecorder.framework/Versions/A/ShortcutRecorder
0x108796000 - 0x10883bff7 +com.mentalfaculty.ensembles (2.6 - 1) <1EFAC5EF-5CE6-3AB2-8ACE-233D7CBF0417> /Applications/BetterTouchTool.app/Contents/Frameworks/Ensembles.framework/Versions/A/Ensembles
0x108892000 - 0x108899fff +com.potionfactory.LetsMove (1.21 - 1.21) <300E0114-3781-356C-938F-A9430CEBA497> /Applications/BetterTouchTool.app/Contents/Frameworks/LetsMove.framework/Versions/A/LetsMove
0x1088a8000 - 0x1088a9fff +com.hegenberg.BTTPluginSupport (1.0 - 1) <86B7767F-BF19-36AB-B81C-764D0CE7D56F> /Applications/BetterTouchTool.app/Contents/Frameworks/BTTPluginSupport.framework/Versions/A/BTTPluginSupport
0x1088f0000 - 0x10890dfff com.apple.AppSSO (1.0 - 1) <670168C7-AB2B-3B76-BA5B-50617B29A934> /System/Library/Frameworks/AppSSO.framework/Versions/A/AppSSO
0x10a949000 - 0x10a95fff7 com.apple.security.csparser (3.0 - 59256.0.0.120.5) <1E3957CA-A40C-38C3-AA7D-2622A9E11CA3> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/csparser
0x10b6d6000 - 0x10b6d9fff com.apple.FileProviderOverride (220.3 - 220.3) /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FileProviderOverride.bundle/Contents/MacOS/FileProviderOverride
0x10b6e2000 - 0x10b6e4fff com.apple.icloud.drive.fileprovider.override (1.0 - 34.1) /System/Library/Frameworks/FileProvider.framework/OverrideBundles/iCloudDrive.bundle/Contents/MacOS/iCloudDrive
0x10b6ed000 - 0x10b704ff3 com.apple.FinderSyncCollaborationFileProviderOverride (1.0 - 1275.5) <0DAEC303-5A82-3FED-AC0D-8BCD2619CFE5> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FinderSyncCollaborationFileProviderOverride.bundle/Contents/MacOS/FinderSyncCollaborationFileProviderOverride
0x10bc3a000 - 0x10bc3d047 libobjc-trampolines.dylib (773.1) <2BEF4035-972C-3DE2-8836-42999FD9C380> /usr/lib/libobjc-trampolines.dylib
0x1113fd000 - 0x11149001f dyld (727) <1236D488-D22B-368E-99F7-23499FFEC65A> /usr/lib/dyld
0x7fff30cd1000 - 0x7fff30f24ff6 com.apple.RawCamera.bundle (9.00.0 - 1200.10) /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff323a3000 - 0x7fff3258aff3 com.apple.AMDRadeonX5000MTLDriver (3.0.47 - 3.0.0) /System/Library/Extensions/AMDRadeonX5000MTLDriver.bundle/Contents/MacOS/AMDRadeonX5000MTLDriver
0x7fff38c34000 - 0x7fff38e82ff7 com.apple.avfoundation (2.0 - 1704) <1447A058-CCC7-3C95-86D4-65780107AD45> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff38e83000 - 0x7fff38f49ff5 com.apple.audio.AVFAudio (1.0 - ???) /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x7fff39067000 - 0x7fff39067fff com.apple.Accelerate (1.11 - Accelerate 1.11) <5D5AB0F5-D796-3026-87CA-51808C3F5B89> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff39068000 - 0x7fff3907efe7 libCGInterfaces.dylib (522) <51C24E9B-2E5E-330A-8E1C-E8384B16F18F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff3907f000 - 0x7fff396eefdf com.apple.vImage (8.1 - 522) <4F7037B2-2081-3A77-8E36-1E27454041AA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff396ef000 - 0x7fff39958fff libBLAS.dylib (1301) <9954B166-1A7A-3DA4-AF14-6B97BCBEE190> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff39959000 - 0x7fff39c20fef libBNNS.dylib (132) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff39c22000 - 0x7fff39fc7fff libLAPACK.dylib (1301) <4D97EE1F-C77C-3D2F-9497-3C57AFEFB2D6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff39fc8000 - 0x7fff39fddff8 libLinearAlgebra.dylib (1301) <9520A463-1A95-362A-A9D9-3A636239086B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff39fde000 - 0x7fff39fe3ff3 libQuadrature.dylib (7) <33DAFF3A-80A6-3D29-BE32-657416D47F76> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff39fe4000 - 0x7fff3a054fff libSparse.dylib (103) <872406D8-9531-392C-857C-4211149F2DB5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff3a055000 - 0x7fff3a067fef libSparseBLAS.dylib (1301) <734E8057-3CE8-3C5F-A60B-63BDB829B453> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff3a068000 - 0x7fff3a23afef libvDSP.dylib (729) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff3a23b000 - 0x7fff3a2f6fd3 libvMisc.dylib (729) <2AE20233-93C1-3989-AED8-DA1E028EBEFA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff3a2f7000 - 0x7fff3a2f7fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <8A1127A0-698C-3BC7-B8E5-20FF0E680371> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff3a2f8000 - 0x7fff3a353ff9 com.apple.Accounts (113 - 113) <74F80889-1A71-32B5-BE75-19DE713A9510> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fff3a498000 - 0x7fff3b22fff1 com.apple.AppKit (6.9 - 1862.10.100) <2161671D-AD1B-33C1-8D55-706E833147F5> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff3b26e000 - 0x7fff3b27efff com.apple.AppleScriptObjC (1.4 - 35) <26FE0C54-7B2E-30F3-A056-B1D0079BE87A> /System/Library/Frameworks/AppleScriptObjC.framework/Versions/A/AppleScriptObjC
0x7fff3b27f000 - 0x7fff3b27ffff com.apple.ApplicationServices (48 - 50) <237CA268-91F7-313F-806E-BBEA9A21C96F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff3b280000 - 0x7fff3b2ebfff com.apple.ApplicationServices.ATS (377 - 485) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff3b384000 - 0x7fff3b3c1ff3 libFontRegistry.dylib (262) <8DC70B4E-0D1E-3D26-BF17-98A4BCC7D6D6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff3b41c000 - 0x7fff3b44bff7 com.apple.ATSUI (1.0 - 1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
0x7fff3b44c000 - 0x7fff3b450ff3 com.apple.ColorSyncLegacy (4.13.0 - 1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff3b4eb000 - 0x7fff3b541ffa com.apple.HIServices (1.22 - 663) <3A029F8B-5297-366A-9B99-111C58E67B58> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff3b542000 - 0x7fff3b550fff com.apple.LangAnalysis (1.7.0 - 1.7.0) <11103CD5-BD3E-3FC7-90D2-8D8A9216EB16> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff3b551000 - 0x7fff3b596ff2 com.apple.print.framework.PrintCore (15 - 515) <1EFE544D-63F0-3F87-8345-2C4D11E419F5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff3b597000 - 0x7fff3b5a1fff com.apple.QD (4.0 - 413) <6CB8EE80-02CD-3CE5-9D0E-A89E2E0378F5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff3b5a2000 - 0x7fff3b5aeff3 com.apple.speech.synthesis.framework (9.0.11 - 9.0.11) <1DD213CF-80B0-35EB-B5C0-D853F67DE051> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff3b5af000 - 0x7fff3b678ff5 com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <3E07C7EA-2ACD-3C27-834E-0515A8659E37> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff3b67a000 - 0x7fff3b67afff com.apple.audio.units.AudioUnit (1.14 - 1.14) <476C498A-5307-3687-9350-3D93AEF97A0E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff3b7b8000 - 0x7fff3b9bfff8 com.apple.AutomatorFramework (2.10 - 479) /System/Library/Frameworks/Automator.framework/Versions/A/Automator
0x7fff3b9ed000 - 0x7fff3bd59ff6 com.apple.CFNetwork (1085.4 - 1085.4) <5C2F4865-3ACA-38FF-980B-BDC140837F7B> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff3bdce000 - 0x7fff3bdcefff com.apple.Carbon (160 - 162) <7A2B90BC-73A8-3C08-9F0A-02D62E72C9E2> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff3bdcf000 - 0x7fff3bdd2ffb com.apple.CommonPanels (1.2.6 - 101) <9FB4AFB3-AE63-3B6D-89BB-740FA6CC12D8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff3bdd3000 - 0x7fff3c0c6ffc com.apple.HIToolbox (2.1.1 - 978) <504D8DFC-5E3B-3330-AE5C-B8932C52D10C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff3c0c7000 - 0x7fff3c0caff3 com.apple.help (1.3.8 - 66) <69DCC671-8BCD-3B29-AB4C-4B97500F5138> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff3c0cb000 - 0x7fff3c0d0ff7 com.apple.ImageCapture (9.0 - 1595.0.1) <6A1EA3BF-AF34-38B6-92CD-EAE15FC0E67C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff3c0d1000 - 0x7fff3c0d1fff com.apple.ink.framework (10.15 - 227) <0F5AB0BD-1E78-37DC-B7FA-A73D3767F53B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff3c0d2000 - 0x7fff3c0ecffa com.apple.openscripting (1.7 - 184) <154EBBDE-CC23-3595-8DBE-410F6CDCC0AE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff3c10d000 - 0x7fff3c10dfff com.apple.print.framework.Print (15 - 271) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff3c10e000 - 0x7fff3c110ff7 com.apple.securityhi (9.0 - 55008) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff3c111000 - 0x7fff3c117ff7 com.apple.speech.recognition.framework (6.0.3 - 6.0.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff3c118000 - 0x7fff3c2a7ff6 com.apple.cloudkit.CloudKit (815 - 815) /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff3c2a8000 - 0x7fff3c2a8fff com.apple.Cocoa (6.11 - 23) <3E9EB784-0FE5-3CDD-87F1-102E420C9D9C> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff3c2b6000 - 0x7fff3c4a1ff7 com.apple.ColorSync (4.13.0 - 3390) <8E05BCEF-0EDC-39E8-A40C-0A4C0890C4DF> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff3c76d000 - 0x7fff3cc2fff2 com.apple.audio.CoreAudio (5.0 - 5.0) <9D52ED80-A10E-3760-854B-6B62206A5E69> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff3cc82000 - 0x7fff3ccb9ffa com.apple.CoreBluetooth (1.0 - 1) <1D2A342D-A6D4-3718-B52F-88A35DED8B61> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff3ccba000 - 0x7fff3d06efe7 com.apple.CoreData (120 - 950) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff3d06f000 - 0x7fff3d16cff2 com.apple.CoreDisplay (1.0 - 107) /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff3d16d000 - 0x7fff3d5e7fe5 com.apple.CoreFoundation (6.9 - 1656.10) <9DBE3917-6ED1-3D82-A02F-1333D4934943> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff3d5e9000 - 0x7fff3dc5dfe0 com.apple.CoreGraphics (2.0 - 1331.0.1) /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff3dc6f000 - 0x7fff3dfbdff4 com.apple.CoreImage (15.0.0 - 800.5.190) /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff3dfbe000 - 0x7fff3e022ffc com.apple.corelocation (2373.0.2 - 2373.0.2) <66C1B173-A33D-3738-824D-AA1072D25945> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fff3e023000 - 0x7fff3e070ff2 com.apple.audio.midi.CoreMIDI (1.10 - 88) <0FD326F8-44BE-3C68-A3ED-7E1E7077D0BA> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x7fff3e073000 - 0x7fff3e351ff0 com.apple.CoreML (1.0 - 1) <89EE58BC-25CB-3DAF-AF7F-2B271455125F> /System/Library/Frameworks/CoreML.framework/Versions/A/CoreML
0x7fff3e352000 - 0x7fff3e4baffc com.apple.CoreMedia (1.0 - 2479.0.2) /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff3e4bb000 - 0x7fff3e51cffe com.apple.CoreMediaIO (1000.0 - 5122) /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff3e5a2000 - 0x7fff3e5a2fff com.apple.CoreServices (1054.11 - 1054.11) <359FBE7C-2124-368F-AA0C-FB2EA6AE0E1E> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff3e5a3000 - 0x7fff3e625ffb com.apple.AE (812 - 812) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff3e626000 - 0x7fff3e907ff7 com.apple.CoreServices.CarbonCore (1210.5 - 1210.5) <525681CA-CB06-3103-9EEF-7642A3D3D6F4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff3e908000 - 0x7fff3e954ff9 com.apple.DictionaryServices (1.2 - 311) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff3e955000 - 0x7fff3e95dfff com.apple.CoreServices.FSEvents (1260 - 1260) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff3e95e000 - 0x7fff3eb88ffb com.apple.LaunchServices (1054.10 - 1054.10) <64056343-83D8-3F4C-A0A2-3264C52FEBFD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff3eb89000 - 0x7fff3ec21ff9 com.apple.Metadata (10.7.0 - 2044.6) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff3ec22000 - 0x7fff3ec4fff7 com.apple.CoreServices.OSServices (1054.10 - 1054.10) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff3ec50000 - 0x7fff3ecb7fff com.apple.SearchKit (1.4.1 - 1.4.1) <7E0FB7C0-E6CE-3E09-9AAE-CBC8E2E6938C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff3ecb8000 - 0x7fff3ecdbffd com.apple.coreservices.SharedFileList (125 - 125) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff3ef48000 - 0x7fff3f00cffd com.apple.CoreTelephony (113 - 7207) <955DD141-DC69-3131-AD08-CBC7FBF5CF9B> /System/Library/Frameworks/CoreTelephony.framework/Versions/A/CoreTelephony
0x7fff3f00d000 - 0x7fff3f1b9ffc com.apple.CoreText (352.0 - 623) <88D5BD51-9546-31FA-BEF1-B4697CE93BBD> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff3f1ba000 - 0x7fff3f1feffb com.apple.CoreVideo (1.8 - 330.0) <7F20F602-C999-34EC-8A5D-4925B2D9A6B8> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff3f1ff000 - 0x7fff3f28bff0 com.apple.framework.CoreWLAN (13.0 - 1437) <65132EC1-7A69-3FC2-9C43-E941234E6108> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff3f44e000 - 0x7fff3f459ff7 com.apple.DirectoryService.Framework (10.15 - 220) /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff3f45a000 - 0x7fff3f505ff4 com.apple.DiscRecording (9.0.3 - 9030.4.5) /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff3f52a000 - 0x7fff3f52fff7 com.apple.DiskArbitration (2.7 - 2.7) <5F5D98E0-9016-3BCB-B266-8374FE2A6138> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff3f718000 - 0x7fff3f82cff7 com.apple.FileProvider (220.3 - 220.3) /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
0x7fff3f838000 - 0x7fff3f841ffa com.apple.finder.FinderSync (1.5 - 1275.5) /System/Library/Frameworks/FinderSync.framework/Versions/A/FinderSync
0x7fff3f845000 - 0x7fff3fc06ffb com.apple.Foundation (6.9 - 1656.10) <024D926E-8253-36DE-9923-A4D35EDFBF32> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff3fc08000 - 0x7fff3fc2fff2 com.apple.GLKit (106 - 106) <7E3DF550-C241-3E08-AD2B-55638838FC96> /System/Library/Frameworks/GLKit.framework/Versions/A/GLKit
0x7fff3fc73000 - 0x7fff3fca2ffb com.apple.GSS (4.0 - 2.0) <7D595D27-E984-362F-A7DF-71F61792F1BE> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff3fdd5000 - 0x7fff3fed9ffc com.apple.Bluetooth (7.0.0 - 7.0.0d93) <4D94CAFD-32EC-3241-9569-176DDC49B669> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff3ff3a000 - 0x7fff3ffdbffb com.apple.framework.IOKit (2.0.2 - 1712) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff3ffdd000 - 0x7fff3ffedff4 com.apple.IOSurface (269.2 - 269.2) /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff4000a000 - 0x7fff4005eff8 com.apple.ImageCaptureCore (1.0 - 1595.0.1) /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff4005f000 - 0x7fff401b3ffe com.apple.ImageIO.framework (3.3.0 - 1955) /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff401b4000 - 0x7fff401b7fff libGIF.dylib (1955) <735C4212-2EAD-301E-B49F-A63896EA0F09> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff401b8000 - 0x7fff40272fe7 libJP2.dylib (1955) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff40273000 - 0x7fff40297fef libJPEG.dylib (1955) <67AD3CA4-B537-3A4D-9749-2F57120A4201> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff40515000 - 0x7fff4052ffe7 libPng.dylib (1955) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff40530000 - 0x7fff40531fff libRadiance.dylib (1955) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff40532000 - 0x7fff4057bff3 libTIFF.dylib (1955) <89A8C750-D6E5-3AA9-AE60-746989142687> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff405a0000 - 0x7fff409d7ff0 com.apple.Intents (1.0 - 1) <0B64DF9C-74A3-3C6C-B0BC-DEC0EA49E0E8> /System/Library/Frameworks/Intents.framework/Versions/A/Intents
0x7fff409da000 - 0x7fff41955ffb com.apple.JavaScriptCore (15608 - 15608.1.27.40.1) <4F5A860A-7341-39B2-B140-474295A6016C> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff4196d000 - 0x7fff4197fff3 com.apple.Kerberos (3.0 - 1) /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff41980000 - 0x7fff41980fff libHeimdalProxy.dylib (76) /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
0x7fff41981000 - 0x7fff419b7fff com.apple.LDAPFramework (2.4.28 - 194.5) /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff41d37000 - 0x7fff41d41ffb com.apple.MediaAccessibility (1.0 - 123) /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff41dfe000 - 0x7fff428aeff3 com.apple.MediaToolbox (1.0 - 2479.0.2) <37676541-942A-3633-B949-F4B8843C0CA5> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff428b0000 - 0x7fff4296cff5 com.apple.Metal (211.30.1 - 211.30.1) /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff4296e000 - 0x7fff42988ff3 com.apple.MetalKit (130 - 130) <41B5B977-CA7A-3DA8-B1A0-0C1706FF8D9C> /System/Library/Frameworks/MetalKit.framework/Versions/A/MetalKit
0x7fff42989000 - 0x7fff429c5ff3 com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <0F8F189E-B727-37EB-950B-635935B76682> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff429c6000 - 0x7fff42a4cfe6 com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <61727DA1-8D56-3C43-894D-6AEFD9750B4E> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff42a4d000 - 0x7fff42a71fff com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff42a72000 - 0x7fff42a86ff8 com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <585213B1-56A0-353E-979C-05DC6FC14F0B> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
0x7fff42a87000 - 0x7fff42be5ff1 com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff42be6000 - 0x7fff42c34ff8 com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <41FA2235-CF9F-384F-AACA-D2D8F37F1513> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
0x7fff42c35000 - 0x7fff42c36ff5 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff42c45000 - 0x7fff43af7ff9 com.apple.ModelIO (215 - 215) /System/Library/Frameworks/ModelIO.framework/Versions/A/ModelIO
0x7fff43b7b000 - 0x7fff43b87ffe com.apple.NetFS (6.0 - 4.0) <1FEEEE23-F7D2-365E-8305-5B642C7C2FAE> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff43b88000 - 0x7fff43ccbffe com.apple.Network (1.0 - 1) /System/Library/Frameworks/Network.framework/Versions/A/Network
0x7fff43ccc000 - 0x7fff43f2dffc com.apple.NetworkExtension (1.0 - 1) /System/Library/Frameworks/NetworkExtension.framework/Versions/A/NetworkExtension
0x7fff43f63000 - 0x7fff43f9bff6 com.apple.OSAKit (1.5 - 107) <231D4598-46A4-3277-BE91-775315EAC7A3> /System/Library/Frameworks/OSAKit.framework/Versions/A/OSAKit
0x7fff466e2000 - 0x7fff4673aff7 com.apple.opencl (3.4 - 3.4) /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff4673b000 - 0x7fff46757ff7 com.apple.CFOpenDirectory (10.15 - 220) <4C79E62F-6D44-3A5D-A9FF-36EFB39452F7> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff46758000 - 0x7fff46763fff com.apple.OpenDirectory (10.15 - 220) <3DDAB6AA-4BE1-3156-99FB-3660B4DE9264> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff470be000 - 0x7fff470c0fff libCVMSPluginSupport.dylib (17.10.19) <67B53AF7-5102-3059-95F2-6B3161519108> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff470c1000 - 0x7fff470c6ff7 libCoreFSCache.dylib (176.1) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff470c7000 - 0x7fff470cbfff libCoreVMClient.dylib (176.1) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff470cc000 - 0x7fff470d4ff7 libGFXShared.dylib (17.10.19) <1BC57A4D-BAC8-3F0F-A98D-25C0BED72342> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff470d5000 - 0x7fff470dffff libGL.dylib (17.10.19) <6749F32B-D1D1-35F4-B1CE-3B3229C2BD35> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff470e0000 - 0x7fff47115fff libGLImage.dylib (17.10.19) <9D4315F3-2602-3C70-9E91-DDD8F5A4E53F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff472a9000 - 0x7fff472e5fff libGLU.dylib (17.10.19) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff47d15000 - 0x7fff47d24ff7 com.apple.opengl (17.10.19 - 17.10.19) <7855C0CA-377F-3635-B77C-0424EA3FBBD8> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff47ed3000 - 0x7fff47fc5ff0 com.apple.PDFKit (1.0 - 815.0.2) /System/Library/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff47fc6000 - 0x7fff480ddff9 com.apple.PencilKit (1.0 - 1) <711063A7-300E-31CB-A672-F98C773701C0> /System/Library/Frameworks/PencilKit.framework/Versions/A/PencilKit
0x7fff48331000 - 0x7fff4835bff2 com.apple.frameworks.preferencepanes (16.0 - 16.0) /System/Library/Frameworks/PreferencePanes.framework/Versions/A/PreferencePanes
0x7fff4835c000 - 0x7fff48362ff1 com.apple.PushKit (1.0 - 1) /System/Library/Frameworks/PushKit.framework/Versions/A/PushKit
0x7fff48466000 - 0x7fff486acff2 com.apple.imageKit (3.0 - 1072) <8C6F45EA-D971-366A-A0BD-E4C579358D2D> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff486ad000 - 0x7fff48b6eff7 com.apple.QuartzComposer (5.1 - 376) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff48b6f000 - 0x7fff48b94ffc com.apple.quartzfilters (1.10.0 - Tag) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fff48b95000 - 0x7fff48c9dff2 com.apple.QuickLookUIFramework (5.0 - 888.1) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fff48c9e000 - 0x7fff48c9efff com.apple.quartzframework (1.5 - 23) /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff48c9f000 - 0x7fff48f19ff3 com.apple.QuartzCore (1.11 - 800.0.2) <8CE65B88-CC8F-3976-B619-F473F65BF5C0> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff48f1a000 - 0x7fff48f73fff com.apple.QuickLookFramework (5.0 - 888.1) /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff48f74000 - 0x7fff48fa5ff3 com.apple.QuickLookThumbnailing (1.0 - 1) <9B921680-A64E-32C7-BEE3-99F6239F6105> /System/Library/Frameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
0x7fff49452000 - 0x7fff49469ffd com.apple.SafariServices.framework (15608 - 15608.1.27.40.1) /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
0x7fff49a55000 - 0x7fff49a6dffd com.apple.ScriptingBridge (1.4 - 79) <332E94A7-8AB3-3F5B-887B-05C970AF7A53> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
0x7fff49a6e000 - 0x7fff49daeffc com.apple.security (7.0 - 59256.0.0.120.5) <78D18E4C-F203-3F31-9666-A8906DF4EF79> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff49daf000 - 0x7fff49e37ff7 com.apple.securityfoundation (6.0 - 55236) /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff49e38000 - 0x7fff49e65fff com.apple.securityinterface (10.0 - 55139) <59D7724D-BED0-3EC3-9A95-A8B30CC691A4> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fff49e66000 - 0x7fff49e6aff0 com.apple.xpc.ServiceManagement (1.0 - 1) /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff4a9f5000 - 0x7fff4aa5ffff com.apple.SystemConfiguration (1.19 - 1.19) <851F2827-B854-3A45-B2E4-FE2921D7EEBF> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff4acdb000 - 0x7fff4b081ff9 com.apple.VideoToolbox (1.0 - 2479.0.2) /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff4b339000 - 0x7fff4ba40fe3 libwebrtc.dylib (7608.1.27.40.1) <2232E858-E91A-3440-A785-A74C0DDEFD40> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libwebrtc.dylib
0x7fff4ba41000 - 0x7fff4dc50ffa com.apple.WebCore (15608 - 15608.1.27.40.1) <282A5DF1-D838-3CB3-A19F-7EBF5795674A> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fff4dc51000 - 0x7fff4de4fff0 com.apple.WebKitLegacy (15608 - 15608.1.27.40.1) <175A5B9D-F2C7-31D7-A278-E83492D5F2FA> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x7fff4de50000 - 0x7fff4e4d9ff7 com.apple.WebKit (15608 - 15608.1.27.40.1) /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff4e864000 - 0x7fff4e91cfe7 com.apple.APFS (1389.0.0 - 1389.0.0) /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff4ef3c000 - 0x7fff4ef47ffd com.apple.accessibility.AXCoreUtilities (1.0 - 1) /System/Library/PrivateFrameworks/AXCoreUtilities.framework/Versions/A/AXCoreUtilities
0x7fff4f0b3000 - 0x7fff4f0bbffe com.apple.AccessibilityBundles (1.0 - 118) <441D86DF-3C28-35B2-B4E6-4E725BAC0094> /System/Library/PrivateFrameworks/AccessibilityBundles.framework/Versions/A/AccessibilityBundles
0x7fff4f117000 - 0x7fff4f117fff com.apple.AccessibilitySupport (2.0 - 190) <2D55472B-33E3-31B4-8987-EE5DAC6A004A> /System/Library/PrivateFrameworks/AccessibilitySupport.framework/Versions/A/AccessibilitySupport
0x7fff4f118000 - 0x7fff4f13fff6 com.apple.AccessibilityEvents (2.0 - 190) /System/Library/PrivateFrameworks/AccessibilitySupport.framework/Versions/A/Frameworks/AccessibilityEvents.framework/Versions/A/AccessibilityEvents
0x7fff4f140000 - 0x7fff4f188ff5 com.apple.AccessibilityFoundation (2.0 - 190) <47354A32-5A01-3B83-8D54-4339E556B9EF> /System/Library/PrivateFrameworks/AccessibilitySupport.framework/Versions/A/Frameworks/AccessibilityFoundation.framework/Versions/A/AccessibilityFoundation
0x7fff4f189000 - 0x7fff4f1c2ff7 com.apple.AccessibilityKit (2.0 - 190) <9B578051-4B6D-3A2D-A609-4CF1DE92AF36> /System/Library/PrivateFrameworks/AccessibilitySupport.framework/Versions/A/Frameworks/AccessibilityKit.framework/Versions/A/AccessibilityKit
0x7fff4f1c3000 - 0x7fff4f1fdff8 com.apple.AccessibilityVisuals (2.0 - 190) /System/Library/PrivateFrameworks/AccessibilitySupport.framework/Versions/A/Frameworks/AccessibilityVisuals.framework/Versions/A/AccessibilityVisuals
0x7fff4f8d8000 - 0x7fff4f8d9ff1 com.apple.AggregateDictionary (1.0 - 1) <0EE35192-12B8-3278-9202-5907389245E2> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
0x7fff4fb99000 - 0x7fff4fce5ff7 com.apple.AnnotationKit (1.0 - 300.1) /System/Library/PrivateFrameworks/AnnotationKit.framework/Versions/A/AnnotationKit
0x7fff4fd21000 - 0x7fff4fd35ffa com.apple.AppSSOCore (1.0 - 1) <6873C562-A50D-3031-9CB9-BF0764533C4C> /System/Library/PrivateFrameworks/AppSSOCore.framework/Versions/A/AppSSOCore
0x7fff5012c000 - 0x7fff50192ff7 com.apple.AppSupport (1.0.0 - 29) <94E114D7-9071-3682-8215-0FE808591ADE> /System/Library/PrivateFrameworks/AppSupport.framework/Versions/A/AppSupport
0x7fff501be000 - 0x7fff501e2ff3 com.apple.framework.Apple80211 (13.0 - 1439.2) /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff50314000 - 0x7fff50323fdf com.apple.AppleFSCompression (119 - 1.0) /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff50420000 - 0x7fff5042bffa com.apple.AppleIDAuthSupport (1.0 - 1) <54B2F7F4-9942-3BAF-94F6-2AFE09338508> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff5046d000 - 0x7fff504b5fff com.apple.AppleJPEG (1.0 - 1) <98339E78-6FF6-38BF-A390-BA2F8B7AD00F> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff50857000 - 0x7fff5087cff3 com.apple.aps.framework (4.0 - 4.0) /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fff5087d000 - 0x7fff50881ff7 com.apple.AppleSRP (5.0 - 1) /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff50882000 - 0x7fff508a4ffb com.apple.applesauce (1.0 - 16.22) <5FDF262C-87CA-3601-ADB9-AB855E4E9E3E> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff50964000 - 0x7fff50967fff com.apple.AppleSystemInfo (3.1.5 - 3.1.5) /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff50968000 - 0x7fff509b8ff7 com.apple.AppleVAFramework (6.1.2 - 6.1.2) /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff50a01000 - 0x7fff50a0ffff com.apple.AssertionServices (1.0 - 167.0.0.120.1) /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
0x7fff50ef4000 - 0x7fff512bcff0 com.apple.audio.AudioResourceArbitration (1.0 - 1) <72BDB97E-563A-32B6-AC0B-26AC148EDE03> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
0x7fff514ea000 - 0x7fff5171cffb com.apple.audio.AudioToolboxCore (1.0 - 1088.4) <9249590B-7BFC-320F-A329-4CB1A14F7534> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
0x7fff5171d000 - 0x7fff5182aff4 com.apple.AuthKit (1.0 - 1) /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff519d9000 - 0x7fff519e2ff3 com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <1034E756-8BB0-3F2A-B181-25C57D62AF45> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff519e3000 - 0x7fff51a83ff2 com.apple.backup.framework (1.11 - 1275.5) <381CB976-4391-3171-80C1-6F9FF8F1A879> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff51a84000 - 0x7fff51b03ff3 com.apple.BaseBoard (447.1 - 447.1) <9929C59F-EEA4-397C-8BE0-6AE5D644EFAC> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
0x7fff51b22000 - 0x7fff51b28ffe com.apple.BezelServicesFW (335 - 335) /System/Library/PrivateFrameworks/BezelServices.framework/Versions/A/BezelServices
0x7fff51c07000 - 0x7fff51c43ff7 com.apple.bom (14.0 - 219) /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff51d61000 - 0x7fff51d95ff3 com.apple.C2 (1.3 - 470) <21213F42-3061-36DE-A18B-978CC3DC162F> /System/Library/PrivateFrameworks/C2.framework/Versions/A/C2
0x7fff527a6000 - 0x7fff527f5fff com.apple.ChunkingLibrary (302 - 302) <63C30CAC-CA06-3277-827C-24748FE170BA> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff5291c000 - 0x7fff529a3ff0 com.apple.CloudDocs (1.0 - 646) <8988EBA1-72A1-3D8A-9432-5D7C61982123> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff536e1000 - 0x7fff536eaff3 com.apple.CommonAuth (4.0 - 2.0) <96A5D529-97CD-36F2-BB58-61E3657C490E> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff536fe000 - 0x7fff53715ff1 com.apple.commonutilities (8.0 - 900) <6A746147-080C-3853-9198-F82F62054500> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
0x7fff53de4000 - 0x7fff541b9fc8 com.apple.CoreAUC (279.0.0 - 279.0.0) <0A591D39-1142-33A8-9FF4-500743689CB5> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff541ba000 - 0x7fff541e8ffb com.apple.CoreAVCHD (6.1.0 - 6100.4.1) <68A433BE-02DA-3E99-AFAA-1A2F5D7FF444> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff5420b000 - 0x7fff5422aff1 com.apple.analyticsd (1.0 - 1) <36E30DBD-6AF7-3B48-9A4B-B3E1FABABAC3> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
0x7fff54329000 - 0x7fff54394ffa com.apple.corebrightness (1.0 - 1) <7B64319C-ED2E-3E0A-9AFD-96A7DD5C4FA4> /System/Library/PrivateFrameworks/CoreBrightness.framework/Versions/A/CoreBrightness
0x7fff544ea000 - 0x7fff544f5ff7 com.apple.frameworks.CoreDaemon (1.3 - 1.3) <9D906F63-2C73-3EF8-B56D-C47CE42748DE> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff544f6000 - 0x7fff546edff8 com.apple.CoreDuet (1.0 - 1) <77D67B81-7A5B-3BEB-9489-AE3EEEB2716A> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
0x7fff546ee000 - 0x7fff54735ff8 com.apple.coreduetcontext (1.0 - 1) /System/Library/PrivateFrameworks/CoreDuetContext.framework/Versions/A/CoreDuetContext
0x7fff54736000 - 0x7fff54746ffe com.apple.CoreDuetDaemonProtocol (1.0 - 1) <49FBE2F8-0519-3370-BF39-DAED16D4127F> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
0x7fff54749000 - 0x7fff5474bfff com.apple.CoreDuetDebugLogging (1.0 - 1) /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
0x7fff5475a000 - 0x7fff5476aff7 com.apple.CoreEmoji (1.0 - 96) /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff54918000 - 0x7fff54a60ff8 com.apple.CoreHandwriting (161 - 1.2) <758D8952-1856-37E6-8EC5-2B7F3D5A31FD> /System/Library/PrivateFrameworks/CoreHandwriting.framework/Versions/A/CoreHandwriting
0x7fff54d95000 - 0x7fff54dffff8 com.apple.CoreNLP (1.0 - 202) <25325657-4C21-3B85-9C6E-492C2342A116> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff550d2000 - 0x7fff550d6fff com.apple.CoreOptimization (1.0 - 1) <922C5D4D-B48F-34E6-A692-042C7C308CB9> /System/Library/PrivateFrameworks/CoreOptimization.framework/Versions/A/CoreOptimization
0x7fff550d7000 - 0x7fff55160ffe com.apple.CorePDF (4.0 - 518) <14424ACB-DEA2-3756-B663-0BA939BCC8F8> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff5523f000 - 0x7fff55247ff8 com.apple.CorePhoneNumbers (1.0 - 1) /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff55248000 - 0x7fff5529cff3 com.apple.CorePrediction (1.0 - 1) /System/Library/PrivateFrameworks/CorePrediction.framework/Versions/A/CorePrediction
0x7fff5596d000 - 0x7fff55990ff7 com.apple.CoreSVG (1.0 - 125) /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
0x7fff55991000 - 0x7fff559c4fff com.apple.CoreServicesInternal (436.5 - 436.5) <07C48AE8-34AB-3D70-ABA6-C9F188B45A98> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff559c5000 - 0x7fff559f0ff0 com.apple.CSStore (1054.10 - 1054.10) /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
0x7fff55ec0000 - 0x7fff55f45ff7 com.apple.CoreSymbolication (11.0 - 64509.86.1) <66EE1AE2-74EA-36B7-87D9-BF286BDB02D8> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff55fdd000 - 0x7fff56106ff3 com.apple.coreui (2.1 - 574.2) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff56107000 - 0x7fff562a3ff6 com.apple.CoreUtils (5.9 - 590.16) <976CADC3-8BAA-3E16-9C93-42CB8C65DAB3> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff563d5000 - 0x7fff563e8ff1 com.apple.CrashReporterSupport (10.13 - 15003) /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff56637000 - 0x7fff56646ff0 com.apple.framework.DFRFoundation (1.0 - 225) <95BE7A0A-D1FE-3B33-A2DC-87D132AEC7CD> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff56647000 - 0x7fff5664bfff com.apple.DSExternalDisplay (3.1 - 380) <58F60C89-9BA4-3920-936A-7AB91E7C442D> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff566b4000 - 0x7fff5672fff0 com.apple.datadetectorscore (8.0 - 655) <682E1EBC-86D8-322B-986E-8CC9DF6460EC> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff5677b000 - 0x7fff567b9ff0 com.apple.DebugSymbols (194 - 194) <29CB7788-5AFF-3E3C-AB33-3835779A7D3E> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff567ba000 - 0x7fff5692dff6 com.apple.desktopservices (1.14 - 1261) <5D022C50-D387-3994-A416-8C7E0ED0FE73> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff56a55000 - 0x7fff56b1eff6 com.apple.DiskImagesFramework (552.0.0.121.1 - 552.0.0.121.1) /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff56b1f000 - 0x7fff56beeffe com.apple.DiskManagement (13.0 - 1636) <50D909F4-E41A-39F6-8003-62801087E9AD> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
0x7fff56bef000 - 0x7fff56bf3ff1 com.apple.DisplayServicesFW (3.1 - 380) /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff56c44000 - 0x7fff56c66ff7 com.apple.DuetActivityScheduler (1.0 - 1) <0C670A44-AE55-3A9D-B880-A0B92B41A188> /System/Library/PrivateFrameworks/DuetActivityScheduler.framework/Versions/A/DuetActivityScheduler
0x7fff56c8e000 - 0x7fff56cc3fff com.apple.SystemConfiguration.EAP8021X (14.0.0 - 14.0) /System/Library/PrivateFrameworks/EAP8021X.framework/Versions/A/EAP8021X
0x7fff56cc4000 - 0x7fff56cc8ff9 com.apple.EFILogin (2.0 - 2) /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff57675000 - 0x7fff5768dff8 com.apple.EmojiFoundation (1.0 - 1) <34450713-E8DE-3E88-B8E1-575AFB67EA6B> /System/Library/PrivateFrameworks/EmojiFoundation.framework/Versions/A/EmojiFoundation
0x7fff576a5000 - 0x7fff57ceaff0 com.apple.vision.EspressoFramework (1.0 - 175.1) /System/Library/PrivateFrameworks/Espresso.framework/Versions/A/Espresso
0x7fff580a5000 - 0x7fff584c0ff1 com.apple.vision.FaceCore (4.3.0 - 4.3.0) /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff58aef000 - 0x7fff58c26ffc libFontParser.dylib (264) <268BFA92-17C1-3A44-8660-40F6171CEDB2> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
0x7fff58c27000 - 0x7fff58c5bfff libTrueTypeScaler.dylib (264) /System/Library/PrivateFrameworks/FontServices.framework/libTrueTypeScaler.dylib
0x7fff58cc0000 - 0x7fff58ccdff4 libhvf.dylib (264) /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
0x7fff5c18b000 - 0x7fff5c18cfff libmetal_timestamp.dylib (902.9.41) <66E9FF1E-73B5-3757-8C68-02DECBD059A1> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_timestamp.dylib
0x7fff5d833000 - 0x7fff5d838ff7 com.apple.GPUWrangler (4.1.30 - 4.1.30) <8A355D37-5DAD-355C-B706-8856E9201505> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff5dc2e000 - 0x7fff5dc53ff0 com.apple.GenerationalStorage (2.0 - 307) <58247ADE-4B73-310F-81AB-7A8F953FFBC9> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff5dc6c000 - 0x7fff5eb9fffd com.apple.GeoServices (1.0 - 1578.20.6.1.3) /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fff5eccc000 - 0x7fff5ecdaffb com.apple.GraphVisualizer (1.0 - 100.1) /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff5ecdb000 - 0x7fff5ece8ffb com.apple.GraphicsServices (1.0 - 1.0) <59947BE7-5113-3731-B544-1474255097FF> /System/Library/PrivateFrameworks/GraphicsServices.framework/Versions/A/GraphicsServices
0x7fff5ed3c000 - 0x7fff5ed48ff5 com.apple.HID (1.0 - 1) <1E128C74-3F1C-34F9-9188-D9503936C85B> /System/Library/PrivateFrameworks/HID.framework/Versions/A/HID
0x7fff5ee62000 - 0x7fff5eed5ff4 com.apple.Heimdal (4.0 - 2.0) /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff5f8cb000 - 0x7fff5f8faff8 com.apple.HelpData (2.3 - 197) <6C82A718-6852-362F-AEFA-3E6DBBB34543> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fff60ee2000 - 0x7fff60eebffe com.apple.IOAccelMemoryInfo (1.0 - 1) <41C0350E-1475-38CD-BDCF-A0E1E93E438E> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
0x7fff60eec000 - 0x7fff60ef4ff5 com.apple.IOAccelerator (438.1.9 - 438.1.9) /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff60ef7000 - 0x7fff60f0dff7 com.apple.IOPresentment (1.0 - 37) <2CFF31EB-C4F1-361A-B716-E6DBB7D3112C> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff61277000 - 0x7fff612beff3 com.apple.IconServices (424.5 - 424.5) /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff61455000 - 0x7fff6145effe com.apple.IntentsFoundation (1.0 - 1) /System/Library/PrivateFrameworks/IntentsFoundation.framework/Versions/A/IntentsFoundation
0x7fff61471000 - 0x7fff61477ff4 com.apple.InternationalSupport (1.0 - 39) /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
0x7fff614df000 - 0x7fff6150cff6 com.apple.IntlPreferences (2.0 - 275) /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0x7fff616b4000 - 0x7fff616d4ff6 com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff6182b000 - 0x7fff618efffd com.apple.LanguageModeling (1.0 - 209) /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff618f0000 - 0x7fff6193dff7 com.apple.Lexicon-framework (1.0 - 67) /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff61944000 - 0x7fff61948ff6 com.apple.LinguisticData (1.0 - 319) <44794542-F3CA-3662-950A-7B1616BCB370> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff6196e000 - 0x7fff61992ff6 com.apple.locationsupport (2373.0.2 - 2373.0.2) <03E47261-116F-3313-869C-586F10891181> /System/Library/PrivateFrameworks/LocationSupport.framework/Versions/A/LocationSupport
0x7fff619eb000 - 0x7fff619f0ffb com.apple.LoginUICore (4.0 - 4.0) <1EC18BA5-B976-348E-A8C2-7A46DB1A23B6> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x7fff61cd0000 - 0x7fff61cd2ffa com.apple.framework.machinesettings (11.0 - 11.0) <9668A5EE-5A0D-38B5-AAC6-532014127D97> /System/Library/PrivateFrameworks/MachineSettings.framework/Versions/A/MachineSettings
0x7fff6213b000 - 0x7fff6213efff com.apple.Mangrove (1.0 - 25) <476D53F2-5215-3B52-B691-D81D2E30E5A3> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff622cb000 - 0x7fff622f1ffe com.apple.MarkupUI (1.0 - 300.1) /System/Library/PrivateFrameworks/MarkupUI.framework/Versions/A/MarkupUI
0x7fff62374000 - 0x7fff6241cfff com.apple.MediaExperience (1.0 - 1) /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
0x7fff6241d000 - 0x7fff62450fff com.apple.MediaKit (16 - 923) /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff62510000 - 0x7fff62865fff com.apple.MediaRemote (1.0 - 1) <2757A6D7-473F-361D-A335-C932ED310F63> /System/Library/PrivateFrameworks/MediaRemote.framework/Versions/A/MediaRemote
0x7fff62866000 - 0x7fff628a0ffa com.apple.MediaServices (1.0 - 1) /System/Library/PrivateFrameworks/MediaServices.framework/Versions/A/MediaServices
0x7fff62ba9000 - 0x7fff62bf3ff4 com.apple.spotlight.metadata.utilities (1.0 - 2044.6) <73084821-0249-3039-AE34-49213D035D26> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
0x7fff62bf4000 - 0x7fff62cc0ffb com.apple.gpusw.MetalTools (1.0 - 1) /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff62d1a000 - 0x7fff62d33ff0 com.apple.MobileAssets (1.0 - 614) <5D5482E7-E8BC-339F-B432-0817E50BC082> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
0x7fff62ed8000 - 0x7fff62ef5ff4 com.apple.MobileKeyBag (2.0 - 1.0) <4015DB43-D688-3744-B13A-9C98D12B71FC> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff62fc2000 - 0x7fff6316cff9 com.apple.Montreal (1.0 - 108) <22D481AB-13D7-3E67-912F-1CF3B75802B2> /System/Library/PrivateFrameworks/Montreal.framework/Versions/A/Montreal
0x7fff6316d000 - 0x7fff6319aff7 com.apple.MultitouchSupport.framework (3000.24 - 3000.24) <7779CA88-B57B-3F29-98E6-B54320BC355C> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff635ff000 - 0x7fff63609fff com.apple.NetAuth (6.2 - 6.2) <8D56481A-A648-3086-8261-67489D12C8AC> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff63f1d000 - 0x7fff63f69ff7 com.apple.OTSVG (1.0 - 623) /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
0x7fff6509d000 - 0x7fff650a8ffe com.apple.PerformanceAnalysis (1.236 - 236) /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff650a9000 - 0x7fff650d1ff0 com.apple.persistentconnection (1.0 - 1.0) /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
0x7fff66969000 - 0x7fff66991ffe com.apple.pluginkit.framework (1.0 - 1) /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
0x7fff669ba000 - 0x7fff669ccff0 com.apple.PowerLog (1.0 - 1) <38E7C08E-CD7F-382A-83A6-8EF3A3419A39> /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog
0x7fff66c61000 - 0x7fff66c8cff4 com.apple.frameworks.preferencepanessupport (13.0 - 13.0) <0EA37820-E1AE-3551-90C8-73D97F9BA56C> /System/Library/PrivateFrameworks/PreferencePanesSupport.framework/Versions/A/PreferencePanesSupport
0x7fff67835000 - 0x7fff6788fff7 com.apple.ProtectedCloudStorage (1.0 - 1) /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff67890000 - 0x7fff678abff5 com.apple.ProtocolBuffer (1 - 270) /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff679d4000 - 0x7fff679d7ff4 com.apple.QuickLookNonBaseSystem (1.0 - 1) <08762ACE-3B19-30B6-BA38-27866A0827AC> /System/Library/PrivateFrameworks/QuickLookNonBaseSystem.framework/Versions/A/QuickLookNonBaseSystem
0x7fff679d8000 - 0x7fff679fbffc com.apple.quicklook.QuickLookSupport (1.0 - 1) <98E356E9-0197-329A-887C-1C9B5EB1EBFC> /System/Library/PrivateFrameworks/QuickLookSupport.framework/Versions/A/QuickLookSupport
0x7fff67a91000 - 0x7fff67b07ff4 com.apple.Rapport (1.7 - 174.20.2) /System/Library/PrivateFrameworks/Rapport.framework/Versions/A/Rapport
0x7fff67cce000 - 0x7fff67cf7ff9 com.apple.RemoteViewServices (2.0 - 147) /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff67e50000 - 0x7fff67e8cff0 com.apple.RunningBoardServices (1.0 - 167.0.0.120.1) /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
0x7fff68be1000 - 0x7fff68c2bff7 com.apple.Safari.SafeBrowsing (15608 - 15608.1.27.40.1) /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/SafariSafeBrowsing
0x7fff69861000 - 0x7fff69872ff7 com.apple.SharedWebCredentials (204 - 204) /System/Library/PrivateFrameworks/SharedWebCredentials.framework/Versions/A/SharedWebCredentials
0x7fff69873000 - 0x7fff6998dffc com.apple.Sharing (1405 - 1405) <373E9992-84C8-3A7A-906C-04EFED5FF795> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff6998f000 - 0x7fff699adff2 com.apple.shortcut (2.16 - 106) /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fff699ae000 - 0x7fff699c8ff3 com.apple.sidecar-core (1.0 - 151.1) /System/Library/PrivateFrameworks/SidecarCore.framework/Versions/A/SidecarCore
0x7fff699c9000 - 0x7fff699dbff0 com.apple.sidecar-ui (1.0 - 151.1) /System/Library/PrivateFrameworks/SidecarUI.framework/Versions/A/SidecarUI
0x7fff6a1f4000 - 0x7fff6a4deff5 com.apple.SkyLight (1.600.0 - 420) <0A91929D-492B-3431-A003-5466FBC92B00> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff6ad20000 - 0x7fff6ad2dffb com.apple.SpeechRecognitionCore (6.0.56 - 6.0.56) <9DC202CD-BFBF-3E57-8DA8-D4F16F314927> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff6ade9000 - 0x7fff6b069ffe com.apple.spotlight.index (10.7.0 - 2044.6) <29BCE53D-D785-3DA8-B498-2184B0E5E641> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
0x7fff6b3e2000 - 0x7fff6b423ff8 com.apple.StreamingZip (1.0 - 1) /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
0x7fff6b533000 - 0x7fff6b53cfff com.apple.SymptomDiagnosticReporter (1.0 - 1212.0.0.120.3) <74E08264-D02F-3074-A095-0C8D039256CB> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
0x7fff6b5ac000 - 0x7fff6b5d6ff0 com.apple.framework.SystemAdministration (1.0 - 1.0) <25E4C187-AA17-3EF3-847A-0F3E95D5180D> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x7fff6b7e4000 - 0x7fff6b7f4ffb com.apple.TCC (1.0 - 1) /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff6bcc6000 - 0x7fff6bd8dff4 com.apple.TextureIO (3.10.9 - 3.10.9) <3FA61B9A-A001-3CCD-885F-2093C0268A86> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff6c640000 - 0x7fff6c641fff com.apple.TrustEvaluationAgent (2.0 - 33) <91E1388C-51E4-3DD4-ABAF-E5782BCA3CFE> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff6d30b000 - 0x7fff6d55bff4 com.apple.UIFoundation (1.0 - 625) <3C955366-5B75-3C03-9ECB-3300CE1918C7> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff6d5d8000 - 0x7fff6d5deff6 com.apple.URLFormatting (111 - 111) <97A5F144-891C-337D-A7E2-3D86B7CC985E> /System/Library/PrivateFrameworks/URLFormatting.framework/Versions/A/URLFormatting
0x7fff6e055000 - 0x7fff6e06eff1 com.apple.UniversalAccessCore (7.0 - 461) <8377104F-AD0F-3240-95CB-4100F8B5BD29> /System/Library/PrivateFrameworks/UniversalAccess.framework/Versions/A/Frameworks/UniversalAccessCore.framework/Versions/A/UniversalAccessCore
0x7fff6e0a2000 - 0x7fff6e0a4fff libUAPreferences.dylib (461) /System/Library/PrivateFrameworks/UniversalAccess.framework/Versions/A/Libraries/libUAPreferences.dylib
0x7fff6e0a5000 - 0x7fff6e0aaff9 com.apple.UniversalAccess (7.0 - 461) <17FF2F44-AC3B-3E26-B1F6-
(SNIP)/usr/lib/libsasl2.2.dylib
0x7fff72b36000 - 0x7fff72b37ff7 libspindump.dylib (276) <9E8DFC48-1797-3187-9C5C-376310065769> /usr/lib/libspindump.dylib
0x7fff72b38000 - 0x7fff72d26fef libsqlite3.dylib (304.1) <9D25B4C2-07A4-3526-90F2-B955CEA1EE11> /usr/lib/libsqlite3.dylib
0x7fff72e1a000 - 0x7fff72e47ffb libssl.46.dylib (46) /usr/lib/libssl.46.dylib
0x7fff72f19000 - 0x7fff72f73ff8 libusrtcp.dylib (1844.0.0.120.1) /usr/lib/libusrtcp.dylib
0x7fff72f74000 - 0x7fff72f77ffb libutil.dylib (57) <78261392-A683-3645-8A3A-CA290233410B> /usr/lib/libutil.dylib
0x7fff72f78000 - 0x7fff72f85ff7 libxar.1.dylib (418) /usr/lib/libxar.1.dylib
0x7fff72f8a000 - 0x7fff7306cff7 libxml2.2.dylib (32.10) <9184FE33-133B-308E-A179-DA8334318182> /usr/lib/libxml2.2.dylib
0x7fff73070000 - 0x7fff73098fff libxslt.1.dylib (16.4) /usr/lib/libxslt.1.dylib
0x7fff73099000 - 0x7fff730abfff libz.1.dylib (76) /usr/lib/libz.1.dylib
0x7fff730d6000 - 0x7fff730d8ff9 liblog_network.dylib (1844.0.0.120.1) <3E5330CA-BF54-39A1-B441-B37CA513705D> /usr/lib/log/liblog_network.dylib
0x7fff73b3e000 - 0x7fff73b43ff7 libcache.dylib (83) <6BB70B87-C454-32CE-A7C7-40029EA0A989> /usr/lib/system/libcache.dylib
0x7fff73b44000 - 0x7fff73b4fff7 libcommonCrypto.dylib (60157) /usr/lib/system/libcommonCrypto.dylib
0x7fff73b50000 - 0x7fff73b57fff libcompiler_rt.dylib (101.1) <670BFA40-896E-3641-8B44-2C3F7794AC37> /usr/lib/system/libcompiler_rt.dylib
0x7fff73b58000 - 0x7fff73b61ff7 libcopyfile.dylib (166) <4473B855-7351-3A22-8445-A106BABDE2CE> /usr/lib/system/libcopyfile.dylib
0x7fff73b62000 - 0x7fff73bf9fc7 libcorecrypto.dylib (837) <8EF936FD-7FCB-3ABB-AE1A-4C67BAAD12E5> /usr/lib/system/libcorecrypto.dylib
0x7fff73d10000 - 0x7fff73d51ff8 libdispatch.dylib (1170.0.0.0.1) <5D3E85BA-496E-311A-A4B9-D5FE755B4148> /usr/lib/system/libdispatch.dylib
0x7fff73d52000 - 0x7fff73d87ff7 libdyld.dylib (727) /usr/lib/system/libdyld.dylib
0x7fff73d88000 - 0x7fff73d88ffb libkeymgr.dylib (30) <4730879B-FAC0-3D72-9AEF-FAB6E25EF77F> /usr/lib/system/libkeymgr.dylib
0x7fff73d89000 - 0x7fff73d95ff7 libkxld.dylib (6110.0.0.121.5) <5DAC58F0-2268-3778-8352-3AEFE8051072> /usr/lib/system/libkxld.dylib
0x7fff73d96000 - 0x7fff73d96fff liblaunch.dylib (1706.0.0.120.1) <27AF6281-5429-39DD-B4E2-AE95F994756C> /usr/lib/system/liblaunch.dylib
0x7fff73d97000 - 0x7fff73d9cff7 libmacho.dylib (947) /usr/lib/system/libmacho.dylib
0x7fff73d9d000 - 0x7fff73d9fffb libquarantine.dylib (108) /usr/lib/system/libquarantine.dylib
0x7fff73da0000 - 0x7fff73da1ff7 libremovefile.dylib (47) <2471C8CA-C0B6-379B-A254-E9A9FEDBD16E> /usr/lib/system/libremovefile.dylib
0x7fff73da2000 - 0x7fff73db9ffb libsystem_asl.dylib (375) <6DCCCF11-0ED9-3A7E-8E92-239633822070> /usr/lib/system/libsystem_asl.dylib
0x7fff73dba000 - 0x7fff73dbafff libsystem_blocks.dylib (74) /usr/lib/system/libsystem_blocks.dylib
0x7fff73dbb000 - 0x7fff73e42fff libsystem_c.dylib (1346) <99719134-AAF7-3D8D-B85F-627D036DEF51> /usr/lib/system/libsystem_c.dylib
0x7fff73e43000 - 0x7fff73e46fff libsystem_configuration.dylib (1054) /usr/lib/system/libsystem_configuration.dylib
0x7fff73e47000 - 0x7fff73e4aff7 libsystem_coreservices.dylib (110) <38070ABE-3AAF-332E-942B-AA868A696099> /usr/lib/system/libsystem_coreservices.dylib
0x7fff73e4b000 - 0x7fff73e52ff7 libsystem_darwin.dylib (1346) <8850250F-6EFC-3E67-AC86-CDF455EA6E66> /usr/lib/system/libsystem_darwin.dylib
0x7fff73e53000 - 0x7fff73e5affb libsystem_dnssd.dylib (1075.120.1) /usr/lib/system/libsystem_dnssd.dylib
0x7fff73e5b000 - 0x7fff73e5cffb libsystem_featureflags.dylib (17) <0793ABFB-5B05-3446-A9F0-7A5F0E48EF7C> /usr/lib/system/libsystem_featureflags.dylib
0x7fff73e5d000 - 0x7fff73eaaff7 libsystem_info.dylib (537) /usr/lib/system/libsystem_info.dylib
0x7fff73eab000 - 0x7fff73ed7ff7 libsystem_kernel.dylib (6110.0.0.121.5) <49272A75-4403-3FC3-9BA6-9963F64FC89F> /usr/lib/system/libsystem_kernel.dylib
0x7fff73ed8000 - 0x7fff73f1fff7 libsystem_m.dylib (3178) /usr/lib/system/libsystem_m.dylib
0x7fff73f20000 - 0x7fff73f47fff libsystem_malloc.dylib (281) /usr/lib/system/libsystem_malloc.dylib
0x7fff73f48000 - 0x7fff73f55ff3 libsystem_networkextension.dylib (1060) <5EA62432-5AA4-3E97-A7D4-8620203D4D7B> /usr/lib/system/libsystem_networkextension.dylib
0x7fff73f56000 - 0x7fff73f5ffff libsystem_notify.dylib (241) /usr/lib/system/libsystem_notify.dylib
0x7fff73f60000 - 0x7fff73f69fe7 libsystem_platform.dylib (218) /usr/lib/system/libsystem_platform.dylib
0x7fff73f6a000 - 0x7fff73f74fff libsystem_pthread.dylib (410) /usr/lib/system/libsystem_pthread.dylib
0x7fff73f75000 - 0x7fff73f79ffb libsystem_sandbox.dylib (1183.0.0.121.1) <8E878E50-41C6-35E2-9180-FAFC495DC2FC> /usr/lib/system/libsystem_sandbox.dylib
0x7fff73f7a000 - 0x7fff73f7cff7 libsystem_secinit.dylib (56) <60DD67AA-2F3E-3227-8F93-0F87ED4E0E87> /usr/lib/system/libsystem_secinit.dylib
0x7fff73f7d000 - 0x7fff73f84ffb libsystem_symptoms.dylib (1212.0.0.120.3) <2455120F-58A6-3484-86CF-9F4A54645C38> /usr/lib/system/libsystem_symptoms.dylib
0x7fff73f85000 - 0x7fff73f9bff2 libsystem_trace.dylib (1135) <8AE584BE-609A-3F08-BE8B-06B03FFCEDD0> /usr/lib/system/libsystem_trace.dylib
0x7fff73f9d000 - 0x7fff73fa2ffb libunwind.dylib (35.4) <5B237183-5F54-31BF-A0F4-394222B7CA1D> /usr/lib/system/libunwind.dylib
0x7fff73fa3000 - 0x7fff73fd7ff6 libxpc.dylib (1706.0.0.120.1) /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 12
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 3049599
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=720.2M resident=0K(0%) swapped_out_or_unallocated=720.2M(100%)
Writable regions: Total=3.3G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=3.3G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 384K 3
Activity Tracing 256K 1
CG image 2560K 20
CoreAnimation 57.6M 189
CoreAnimation (reserved) 4K 1 reserved VM address space (unallocated)
CoreData Object IDs 4100K 2
CoreGraphics 8K 1
CoreImage 4K 1
CoreUI image data 2044K 18
Foundation 4K 1
Image IO 192K 15
Kernel Alloc Once 8K 1
MALLOC 657.8M 125
MALLOC guard page 72K 14
MALLOC_MEDIUM (reserved) 2.2G 20 reserved VM address space (unallocated)
MALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)
Memory Tag 242 12K 1
Memory Tag 251 28K 2
SQLite page cache 1280K 20
STACK GUARD 56.1M 22
Stack 18.7M 22
VM_ALLOCATE 100K 14
__DATA 46.9M 434
__DATA_CONST 44K 5
__FONT_DATA 4K 1
__LINKEDIT 362.2M 15
__OBJC_RO 31.4M 1
__OBJC_RW 1712K 1
__TEXT 358.0M 428
__UNICODE 564K 1
libnetwork 128K 8
mapped file 233.4M 105
shared memory 664K 19
TOTAL 4.4G 1512
TOTAL, minus reserved VM space 1.8G 1512
BTT is not launching for me; the following is in the log:
fault: One or more models in this application are using transformable properties with transformer names that are either unset, or set to NSKeyedUnarchiveFromDataTransformerName. Please switch to using "NSSecureUnarchiveFromData" or a subclass of NSSecureUnarchiveFromDataTransformer instead. At some point, Core Data will default to using "NSSecureUnarchiveFromData" when nil is specified, and transformable properties containing classes that do not support NSSecureCoding will become unreadable.
that's just a warning for the future. If possible check whether there is a crashlog in the macOS console.app under user reports.
I was able to reproduce the crash and hope the workaround I added in v3.101 alpha works. (It's a very weird macOS bug)
i got the following crash report:
BetterTouchTool_2019-07-23-155634_MacBook-Pro.crash (96.7 KB)
again, thanks for your help!
Very weird crash. Thanks for sharing.
I have no idea what could cause it, but please let me know if it happens multiple times. It might however be a system bug.
komisch. tried reinstalling, but doesn't work either:
i think i need to downgrade, as i can't use my mac without btt.
Where did you download BTT? If it's the official version from https://folivora.ai/downloads it should start fine on Catalina.
Blockt vielleicht irgend eine Firewall die Apple Software-verification Verbindungen?
Generell scheint es zu funktionieren (auf meinen 2 Catalina Rechnern und bei einer ganzen Menge Nutzer die schon auf Catalina sind laut Update-Logs).
Aber es kann natürlich auch immer sein, dass die betas noch irgendwelche wilden Bugs haben. Am Montag oder Dienstag sollte ja Beta 5 da sein
I'm getting crashes every time I open after installing Beta 5. The icon will flash on and off in the Touch Bar but nothing shows up in console... Help!
