As a Windows user I don't want to give 10 $ for this software...
I already switched "command/control" keys (like in Windows in order to do CTRL+X/C/V)
ENTER - open folder/file - not working
DELETE - delete file/folder - not working
Chrome - CTRL+TAB, loop on tabs - not working
Chrome - F5, reload window - not working
Put top left buttons (close/minimize/maximize) to the right like windows - not working
Many things that I wanted to change - missing or impossible to do with this tool.
before trying to use macOS like windows try to learn basics of macOS. at least i have used windows 20+ years and still goes on. You will never experience windows on mac and same for reverse. Actually i switched ctrl with alt key on windows because placement for modifier keys better. just give a chance to macOS for a while
