losing certain configurations after exporting and then importing them
Regarding the issue of losing certain configurations after exporting and then importing them
1.Before exporting, a certain trigger operation configuration configured a "wait for condition to be true" option,
  1. After exporting the file and selecting to import it, it was found that the configuration conditions for the operation configuration of the trigger were not imported
Chinese description:
关于导出配置后再导入,某些配置丢失的问题
1.导出前,某触发器操作配置里配置了一项“等待条件成立”,
2.导出文件后,再选择导入这个文件,发现该触发器的操作配置的配置条件没有导入进来
thanks for reporting, I’ll have a look!
should be exporting correctly starting with 4.543 alpha!(uploading now)
