Hi!
New to BTT but love it so far with shortcuts to apps etc.
Bought a Stream Deck today and want to do the following:
I want 3 buttons (on my Stream Deck) as follows:
BTN1 = CTRL+OPTION (continuous press until Stream Deck button is released, and then disable the press with the release of the Stream Deck button)
BTN2 = OPTION
BTN3 = CMD+OPTION
I have tried for an hour to set it up as I want it but the closest I came was that click 1 enabled for example CMD and click two on the same button disabled it. I want a "long press" version simulating me "holding CMD and releasing" - in short I want the Stream Deck button to do exactly as the button does on my keyboard (while pressing hold it, and when releasing the button release the modifier key combos)
Thank you to anyone that can help me out!
Peace.
