So I have a few buttons which trigger rather intrusive automations which are annoying if triggered accidentally.
I know there is long press configuration which is generally used for a secondary action, and if I make an action first I can kinda hack my way to what I want...
But it would be cool if it was just a parameter available to all buttons that allows you to set them to... "Only trigger after long press" which would allow you to define a delay before trigger. I find even a teeeeny delay has a significant debounce for accidental touches.
