At a rate of about 5 per second, I'm seeing the errors below.
default com.apple.securityd 14:52:50.796875 -0400 CSSM Exception: -2147413737 CSSMERR_DL_DATASTORE_DOESNOT_EXIST BetterTouchTool
I ran sudo sysdiagnose securityd and examined the output. In the fs_usage.txt file of sysdiagnose output. I believe the problem is that for some reason BTT is trying to open a keychain that I have for a work project. I do not open it on my mac. Below is a partial output.
14:45:13.387079 getattrlist /private 0.000011 BetterTouchTool.1809358
14:45:13.387084 getattrlist /private/var 0.000005 BetterTouchTool.1809358
14:45:13.387088 getattrlist /private/var/db 0.000004 BetterTouchTool.1809358
14:45:13.387093 getattrlist /private/var/db/crls 0.000004 BetterTouchTool.1809358
14:45:13.387096 getattrlist [ 2] /private/var/db/crls/crlcache.db-db 0.000003 BetterTouchTool.1809358
14:45:13.387106 getattrlist /private 0.000004 BetterTouchTool.1809358
14:45:13.387110 getattrlist /private/var 0.000003 BetterTouchTool.1809358
14:45:13.387114 getattrlist /private/var/db 0.000003 BetterTouchTool.1809358
14:45:13.387117 getattrlist /private/var/db/crls 0.000003 BetterTouchTool.1809358
14:45:13.387120 getattrlist [ 2] /private/var/db/crls/crlcache.db 0.000002 BetterTouchTool.1809358
14:45:13.387130 getattrlist /Users 0.000004 BetterTouchTool.1809358
14:45:13.387134 getattrlist /Users/user1 0.000003 BetterTouchTool.1809358
14:45:13.387138 getattrlist /Users/user1/Documents 0.000004 BetterTouchTool.1809358
14:45:13.387142 getattrlist /Users/user1/Documents/Work 0.000004 BetterTouchTool.1809358
14:45:13.387146 getattrlist /Users/user1/Documents/Work/project migrate 0.000004 BetterTouchTool.1809358
14:45:13.387149 getattrlist [ 2] /Users/user1/Documents/Work/project migrate/ProjectmigrateFileVaultMaster.keychain-db 0.000002 BetterTouchTool.1809358
14:45:13.387159 getattrlist /Users 0.000004 BetterTouchTool.1809358
14:45:13.387163 getattrlist /Users/user1 0.000003 BetterTouchTool.1809358
14:45:13.387167 getattrlist /Users/user1/Documents 0.000003 BetterTouchTool.1809358
14:45:13.387171 getattrlist /Users/user1/Documents/Work 0.000004 BetterTouchTool.1809358
14:45:13.387175 getattrlist /Users/user1/Documents/Work/project migrate 0.000004 BetterTouchTool.1809358
14:45:13.387178 getattrlist [ 2] /Users/user1/Documents/Work/project migrate/ProjectmigrateFileVaultMaster.keychain 0.000002 BetterTouchTool.1809358
14:45:13.387187 getattrlist /Users 0.000004 BetterTouchTool.1809358
14:45:13.387191 getattrlist /Users/user1 0.000003 BetterTouchTool.1809358
14:45:13.387194 getattrlist /Users/user1/Documents 0.000003 BetterTouchTool.1809358
14:45:13.387198 getattrlist /Users/user1/Documents/Work 0.000004 BetterTouchTool.1809358
14:45:13.387202 getattrlist /Users/user1/Documents/Work/project migrate 0.000004 BetterTouchTool.1809358
14:45:13.387205 getattrlist [ 2] /Users/user1/Documents/Work/project migrate/FileVaultMaster.keychain-db 0.000002 BetterTouchTool.1809358
14:45:13.387216 getattrlist /Library 0.000004 BetterTouchTool.1809358
14:45:13.387221 getattrlist /Library/Keychains 0.000004 BetterTouchTool.1809358
14:45:13.387223 getattrlist [ 2] /Library/Keychains/System.keychain-db 0.000002 BetterTouchTool.1809358
14:45:13.387289 getattrlist /private 0.000006 BetterTouchTool.1809358
14:45:13.387293 getattrlist /private/var 0.000004 BetterTouchTool.1809358
14:45:13.387297 getattrlist /private/var/db 0.000003 BetterTouchTool.1809358
14:45:13.387301 getattrlist /private/var/db/crls 0.000004 BetterTouchTool.1809358
14:45:13.387304 getattrlist [ 2] /private/var/db/crls/crlcache.db 0.000002 BetterTouchTool.1809358
14:45:13.387312 getattrlist /private 0.000004 BetterTouchTool.1809358
14:45:13.387315 getattrlist /private/var 0.000003 BetterTouchTool.1809358
14:45:13.387319 getattrlist /private/var/db 0.000003 BetterTouchTool.1809358
14:45:13.387323 getattrlist /private/var/db/crls 0.000004 BetterTouchTool.1809358
14:45:13.387326 getattrlist [ 2] /private/var/db/crls/crlcache.db 0.000002 BetterTouchTool.1809358
14:45:13.387335 getattrlist /private 0.000004 BetterTouchTool.1809358
14:45:13.387339 getattrlist /private/var 0.000003 BetterTouchTool.1809358
14:45:13.387342 getattrlist /private/var/db 0.000003 BetterTouchTool.1809358
14:45:13.387346 getattrlist /private/var/db/crls 0.000004 BetterTouchTool.1809358
14:45:13.387349 getattrlist [ 2] /private/var/db/crls/crlcache.db 0.000002 BetterTouchTool.1809358
14:45:13.387356 getattrlist /private 0.000004 BetterTouchTool.1809358
14:45:13.387360 getattrlist /private/var 0.000003 BetterTouchTool.1809358
14:45:13.387364 getattrlist /private/var/db 0.000003 BetterTouchTool.1809358
14:45:13.387368 getattrlist /private/var/db/crls 0.000003 BetterTouchTool.1809358
14:45:13.387370 getattrlist [ 2] /private/var/db/crls/crlcache.db 0.000002 BetterTouchTool.1809358
14:45:13.387376 statfs64 /private/var/db/crls 0.000004 BetterTouchTool.1809358
14:45:13.387384 getattrlist /private 0.000004 BetterTouchTool.1809358
14:45:13.387388 getattrlist /private/var 0.000003 BetterTouchTool.1809358
14:45:13.387392 getattrlist /private/var/db 0.000003 BetterTouchTool.1809358
14:45:13.387396 getattrlist /private/var/db/crls 0.000003 BetterTouchTool.1809358
14:45:13.387398 getattrlist [ 2] /private/var/db/crls/crlcache.db 0.000002 BetterTouchTool.1809358
14:45:13.387404 getattrlist /private 0.000004 BetterTouchTool.1809358
14:45:13.387408 getattrlist /private/var 0.000003 BetterTouchTool.1809358
14:45:13.387412 getattrlist /private/var/db 0.000003 BetterTouchTool.1809358
14:45:13.387416 getattrlist /private/var/db/crls 0.000003 BetterTouchTool.1809358
14:45:13.387418 getattrlist [ 2] /private/var/db/crls/crlcache.db 0.000002 BetterTouchTool.1809358
14:45:13.387502 getattrlist /private 0.000006 BetterTouchTool.1809358
14:45:13.387506 getattrlist /private/var 0.000003 BetterTouchTool.1809358
14:45:13.387510 getattrlist /private/var/db 0.000003 BetterTouchTool.1809358
