Logitech mouse still feels sluggish/floaty with BTT until HIDMouseAcceleration is reset
Logitech mouse pointer movement can still feel sluggish/floaty on macOS even after disabling mouse acceleration in macOS and configuring mouse behavior through BetterTouchTool.
In this setup, BetterTouchTool was being used instead of Logitech G HUB / Logi Options because Logitech's driver software is heavy and performs poorly. BetterTouchTool is much better suited for mouse buttons, gestures, scrolling behavior, window actions, and app-specific workflows.
However, even with Logitech driver software not installed and mouse behavior handled through BetterTouchTool, the pointer did not feel like the same mouse on Windows/Linux, or like the same mouse on a Mac with Logitech's driver software installed.
The concrete low-level issue found:
HIDMouseAcceleration=45056
was being applied to the Logitech receiver, even though mouse acceleration was supposed to be disabled. Applying:
hidutil property --matching '{"VendorID":1133}' --set '{"HIDMouseAcceleration":-1}'
changed the receiver to:
HIDMouseAcceleration=18446744073709551615
and immediately fixed the sluggish/floaty pointer feel.
This may be a BetterTouchTool Logitech mouse integration issue, or it may be a macOS HID/device-state issue that BetterTouchTool could detect/fix when it manages Logitech mice.
Current workaround / reproduction details:
Affected input device
Logitech G502 X via Logitech Powerplay mat / USB receiver.
macOS sees it as:
Manufacturer: Logitech
Product: USB Receiver
VendorID: 1133
ProductID: 50490
ReportInterval: 1000
None yet. The relevant evidence is the ioreg / hidutil output above.
Device information
Type of Mac: MacBook Pro, Mac17,8, Apple M5 Pro, 48 GB memory
macOS version: macOS 26.4.1, build 25E253
BetterTouchTool version: 6.512, build 2026051202
Additional information
No crash logs. This is not a crash.
Important context:
  • Logitech G HUB / Logi Options are intentionally not installed.
  • BetterTouchTool is used for mouse button/gesture behavior.
  • Karabiner-Elements is used for keyboard remapping, not mouse behavior.
  • Karabiner's Logitech pointing-device handling was disabled/removed while testing.
  • The Logitech receiver reports 1000 Hz, so the issue does not appear to be polling rate.
  • macOS global com.apple.mouse.scaling was already set to -1, but the receiver still had HIDMouseAcceleration=45056 until fixed with hidutil.
To be clear this may have something to do with Powerplay and how that interacts with it.
