Logitech Litra Glow control without Logitech software
Would it be possible to control the Logitech Litra Glow directly with BTT? Mainly just turning it on/off and adjusting the brightness and color temperature.
It would be nice to do this through BTT without having to install Logitech's software just for controlling the light.
Maybe this is already possible and I just couldn't find any info about it?
I don't have a litra to test, but based on what I found I added some actions you can try. (Luckily they seem to use the same protocol as Logitech Mice and Keyboards)
In BTT 6.740 (uploading now) search the predefined actions for "Logitech Litra", then you should see
  • Logitech Litra: Turn On (Optionally Set Brightness & Color Temperature)
  • Logitech Litra: Turn Off
  • Logitech Litra: Toggle On / Off
  • Logitech Litra: Set Brightness
  • Logitech Litra: Increase Brightness
  • Logitech Litra: Decrease Brightness
  • Logitech Litra: Set Color Temperature
  • Logitech Litra: Increase Color Temperature (Cooler)
  • Logitech Litra: Decrease Color Temperature (Warmer)
Super! I’ll test it this week and report back on how it went.
I see the options, but as soon as I select any Litra action, BTT 6.1162 crashes immediately.
All Logitech software has been removed from this computer.
If it is at all meaningful, I'm also using a Logitech MX4 mouse successfully with BTT.
oh could you send the crashlog to me? (andreas@folivora.ai) You'll find it in the macOS console app's crash report section
