Hi. I am using the music recording program Logic Pro for MacOS. It's great but the only thing I hate about it is there is no way to reverse the zoom scroll when using a mouse to zoom in Logic.
When you want to zoom vertically in Logic, you have to hold (option) and then scroll DOWN on the mouse wheel.. the same goes for when you want to zoom horizontally, you have to hold (option+shift) and scroll DOWN on the mouse wheel. This is completely backwards to how most all other programs work, where you would scroll UP with the mouse wheel to zoom in.
Is there anyway to program this in Better Touch Tool so that that it will zoom when I scroll UP instead of DOWN? It's not as easy as inverting the scroll, because then it will also invert when I am simply scrolling up/down/left/right on in the program, which I do not want.
I only want it to reverse this zoom scroll function under 2 circumstances-
- Only in Logic Pro App
- Only when the "Option" key is being held down (since this would cover both the horizontal and vertical zoom functions)
Any suggestions would be greatly appreciated. Thanks
-Dan
