Logi special key occasionally not recognised again
Using a Logitech MX Mechanical Mini for Mac and BTT's special Logi mappings, I have assigned an action to the top right key showing a moon and a lock icon (recognised by BTT as "Logi Do Not Disturb"). In most cases, the assigned function (sleep) triggers, but recently it sometimes did not. Instead, nothing happens. At some point, the intendend behavior does return but I have not been able to reproduce the circumstances. It is not merely that I have to wake after sleep. The logs are attached, where I repeatedly press the key in question and do not get a result.
Many thanks for the help!
  • Type of Mac: MacBook Pro M4
  • macOS version: macOS 26.4.1
  • BetterTouchTool version: 6.378 (issue also present in 6.365)
  • Logitech MX Mechanical Mini for Mac
Logs attached
Logs.txt (52.2 KB)
