Note:
After a while, maybe a minute, the BetterTouchTool stops working based on shortcuts. When I click on the icon in the menu bar it shows Register/Buy (-79 days left), but when I click on it, it restarts and goes away, but disables after a minute again. I have a license now, but did also run out a trial before.
It's always been quite unstable from the beginning too, crashing whenever I clicked on the configuration. It worked for a while but is now really buggy.
n/a
- Type of Mac: Macbook Pro M1 Pro
- macOS version: Sequoia 15.5
- BetterTouchTool version: 5.484 alpha but also on the latest stable
Just collected a log report:
CrashBTT.txt (47.3 KB)
