Hi, I am encountering a reproducible issue related to menu bar rendering when using BetterTouchTool.
Environment: macOS (latest version) + BetterTouchTool (latest version) + 0 external displays setup
Issue: After switching Spaces using a BetterTouchTool gesture/shortcut (the one that hides animation), the left side of the menu bar becomes invisible:
The menu and application menus are not rendered
However, the area is still interactive / clickable
If I click where the menu or menu items should be, they open correctly
The right side of the menu bar (Control Center, system icons, clock) remains fully visible and functional.
Restart did not fix the problem. Quitting BetterTouchTool prevents the issue entirely.
Thank you for any advice given.
A
P.S thank you for your hard work on this project
