I saw Alpha release 4.462 said "If you set a trigger to require modifier keys to be set, they can now differentiate between left & right modifier keys." It doesn't work for me on the F1, F2, & F7-F12 function keys. Left/right modifiers are not recognized when entering them as a keyboard shortcut. Is this a bug? Left/right modifiers are recognized with all other keys I've tried.
I'm using Sonoma 14.4 on an M4 MacBook Pro. Have restarted my device a few times.
which mode is your macOS set to for the F-Keys in System Setting => Keyboard => Keyboard Shortcuts? Are they behaving like standard F-Keys or do you use the macOS multi-media keys?
Yes, I have it turned off like your photo. When I turn it on, ALL function keys are differentiated. I use volume and screen brightness constantly though, so I'll probably need to keep this toggled off. I'm not sure if there is a way to do modifier key differentiation, but it would be nice.
