Launchpad Replacement for >= macOS 27
Type
Preset
Categories
Floating Menus, Launcher
Summary
Description and setup
This preset requires BetterTouchTool 6.933. It is a basic Launchpad replacement for current macOS versions.
It uses a floating menu with the new launchpad widget and a keyboard shortcut to show it (ctrl+opt+cmd+L) however you can use any trigger you want to show the launchpad replacement via the "Toggle FLoating Menu Hidden / Shown" action.
Version
1.0.0
Tested with BetterTouchTool version
6.933
Download
Launchpad.bttpreset (11.4 KB)
It looks good. I never used Launchpad, so I don’t miss it either. One of the things I disliked about it was how awkward it was to move between pages or move apps into folders. Is there any way to make this easier in BTT? I’m mainly interested in selecting multiple icons at once, a bit like in Finder, where I can hold Shift to select a range of consecutive files or use Cmd-click to select individual files.
