Keys not triggering on certain websites
Sometimes I have web pages with login boxes where BTT shortcuts are not registered. In this for example the '' I've mapped to trigger something. However, it writes this character into the username or password field. Any idea how to stop this?
I guess that the "Secure input" is activated. Next time check in BTT's menu bar icon.
correct, unfortunately in secure input mode e.g. shortcuts involving fn can not work, also differentiating between left / right modifiers can not work if secure input is active
There is no way to prevent this
BTT's menu bar icon does not indicate anything like that, unfortunately. Is there another app you know of with which I can verify that the secure input activated messages does show up at all?
password fields do always trigger secure input mode, even if BTT might not immediately be able to show it
