The Bug :
I have a new issue with BTT since buying a new M2 Macbook.
I don't have this issue on my other work Macbook nor did I have the issue when using previous home Macbook.
The issue is regarding random behaviours when assigning a keyboard shortcut action to be used by themselves or in a list of actions to be triggered.
The example that is the most striking in my daily use would be adding an ARROW key (left, down, up, right) or the TAB key. Those are part of a lot of my triggers when having to select options from pulldown menus for example.
For some reason, when using the arrow key or tab key in Chrome, it doubles some of the arrows or tab shortcuts.
One arrow would sends two arrows, two arrows would send three, three arrows would send five.
The issue does not seem to be reproduced in other apps.
I tried in the Notes app, and three arrows were three arrows.
However, the created shortcut would not work at all in Notes unless I added a short delay before the first arrow.
It also only seems to be affecting the arrows and tab keys.
For example, if my trigger in Chrome is assigned to send a LETTER A keyboard shortcut, then LETTER B, then LETTER C - it would be written ABC (but requires a delay to be working).
**Affected input device : Keyboard shortcuts.
**Screenshots and movie ( I hope it helps !) :
Type of Mac: MacBook Air M2 16GB
macOS version: Ventura 13.5.2
BetterTouchTool version: (please post the exact version - not just "the latest one") 4.273
