Dunno what happened - I did set up some keyboard sequences that work fine, but they are not shown in the config menu anymore - I am confused. Where can I get the visible again?
If you can rule out option 1 and 2, please go to Help => Export Diagnostic Debug Information and send the result to andreas@folivora.ai, maybe I can see something
I checked ( that's more than weird. I did set them up in BTT as I saw that here - but it works with BTT disabled too. Any chance that BTT cleaned that up as those settings seem to be in MacOS?
yep I understand (:0 Only thing I can imagine is that those combinations are actually macOS. I definitely did set them up in BTT as I learned about those sequences here, but as they are form macOS BTT just didn't save them. No other explanation I can think as I definitely wouldn't know where to set them up otherwise
