Keyboard-oriented navigation system
This is a (simple) keyboard-oriented navigation system that moves the cursor within text or selects text. It also works (to some extent) in the BTT Launcher, App Switcher, the Clipboard Manager, various menus, etc.
:rocket:CAG 4 + Letter _export.bttpreset|attachment (96.0 KB)
4 Steuerung.bttpreset (4.0 KB)
4 Correction Triggers.bttpreset (15.6 KB)
The "control keys" are 4 and 3 (left hand). They function as modifiers when used with a letter key (right hand).
4 alone --> 4
4 + j --> One character to the left
4 + k --> One character to the right
4 + u --> One line up
4 + Space --> One line down
4 + h --> Start of line
4 + ;/ö --> End of line
4 + Backspace --> Forward delete
4 + Enter --> Enter
4 + z --> ESC
If j, k, u, or Space are held down, keys repeat is enabled.
4 + L --> Launcher
4 + M --> App Switcher
If 3 is pressed in addition to 4:
4 + 3 + j --> Selects text to the left of the cursor
4 + 3 + k --> Selects text to the right of the cursor
Release 3 --> Copies the selected text
4 + ,/ä --> Pastes the text
Why keys 4 and 3?
Because it works. F and d would correspond to the “Homerow concept” but that doesn’t work for fast typing because the keys are pressed when released. If you type slowly, feel free to try it.
4 and 3 are easily accessible and can be pressed blindly with the index finger (4) and middle finger (3). After a short getting-used-to period, it’s perfect.
I don't know if this is useful to anyone. Since I made it for myself, I thought I'd post it. And of course, you can customize it however you like.
