- On macOS 10.14.6, set BTT 3.160 (1333) to launch at startup.
- Restart Mac and login.
Result: There is significant keyboard lag/unresponsiveness. I have to press a key several times before it outputs onto the screen, and some keystrokes are simply discarded. (I am using a USB keyboard.)
I had not experienced this behavior prior to updating today to macOS 10.14.6. However, I simultaneously updated to the latest BTT alpha (1333), so I do not know which update (macOS or BTT) is responsible for the behavior. Activity Monitor showed CPU as relatively idle.
Thinking there was perhaps an issue with macOS, I did a complete reinstall of macOS 10.14.6 using the full installer on top of my existing OS (which was already running 10.14.6.). That did not resolve the issue.
Keyboard (USB)
- Type of Mac: iMac17,1
- macOS version: 10.14.6
- BetterTouchTool version: (please post the exact version - not just "the latest one") 3.160 (1333)
Workarounds:
- The keyboard lag ceases once BTT is terminated.
- The keyboard lag also ceases if BTT is simply restarted; and it doesn't appear that the problem resurfaces until the next login.
- You can also simply not start BTT at startup and simply launch it after login.
