Sorry, a little afraid to lock myself out. ![]()
I put this on:
Left click, short = normal left click
Left click, long = something
Right?
Ah, or I set up the left click with a modifier before for safety...
I put this on:
Right?
you don't need to add left click short, I have made it so that if you only have a long click defined, the standard click will still work. Worst case you can use right click to disable the trigger ![]()
Das ist richtig gut durchdacht :-), danke, Andreas.
Sorry, bin wohl zu blöd... BTT will hier einen Modifier...
if you want to do it without modifier you need to check the checkbox with the warning triangle.
That is what I did before. Unfortunately, it does not work. With the modifier (shift) it does. ![]()
I just tried with a fresh install of BTT to make sure none of my settings interfere. This seems to work fine here (I marked all the settings I made):
I deleted my action and set it up again. Now it works. Sorry, no idea why, I had it that way before.
Anyway, thanks, it works ![]()
