I have a few Key Sequences setup to only work within specific apps that have stopped working
I have ⌘•⇧•R•R mapped to ⌃⌥⇧O in Xcode and I have the same sequence mapped to a menubar item in Nova.
If they are in a specific apps the key sequences do not work, however if they are in the Global shortcut category they do.
MacBook Pro Keyboard
- Type of Mac: 16" MacBook Pro
- macOS version: macOS 12.0 developer beta 2
- BetterTouchTool version: 3.571
