Note:
Before bug reporting, please make sure you have tried the latest (alpha) version of BetterTouchTool and that you have already tried to restart your system :-). If you encounter a crash, please attach a crash log from the macOS Console.app's "Crash Reports" section.
I want to map a three-finger swipe left to a key in an RDP application. I've tried both keyboard shortcuts and modifier keys, but neither works. I've set the same configuration in RDP and local Edge applications, and a key detection website shows the gesture is correctly translated into a key sequence. What should I do?
MacBook Trackpad
btt config:
The actual key sequence received in the RDP (remote win):
The actual key sequence received in the edge (this macos):
- Type of Mac: macbook pro m1
- macOS version: 26.0.1 (25A362)
- BetterTouchTool version: 5.750
