idk if someone has already mentioned this but like my title say, simply put: KEEPS POPPING UP....working fine but dock icon keeps opening up randomly...
Thanks in advance!
Thanks in advance!
something similar... the window opens even when I don't touch anything. I've set up some virtual desktops and it also switches to the main desktop. very annoying when I'm in a meeting.
hmmm im wondering if a recent change i made did it....did you disable dock popping up on the other monitors? im gunna try to revert that and see if that changes anything
No, I don't think so. It started soon after an update of the BTT app. But I can't remember which one.
ok, interesting. for me, so far, it's going well, but if that changes, ill be sure to update here. thanks for your feedback to
in the mean time, go to
system preferences
mission control
make sure "Displays have separate Spaces" is CHECKED
i previously unchecked it because i used multiple monitors and would hate having the dock pop up on every window but ive notced that unchecking this also affected other screens if i did full screen video on one of them, etc, etc, so this may be the reason. we shall see.
hmmm, I never unchecked that one.
im going good 24 hours later. i also updated to the latest big sur update. i run macbook 16 inch 2019 fwiw.
ok, after several days, its popping up again. idk why. i'll see if anything changed in my setting or what app is running that may be affecting it. i had restarted my laptop so i wonder what is running in the background that is affecting it. im sure there is a smarter more technical way of look at this but oh well. im not a code or programmer type
Not sure if your problem matches mine, but it sounds like. In my case the main configuration window of BTT randomly pops up in the center of my main screen. I have no dock icon visible and BTT works as expected. It's just very annoying to be working and suddenly the configuration window pops up and takes focus.
FWIW: I also have a Macbook 16" 2019, with Big Sur 11.4 and an external screen I use as main screen.
I updated Big Sur and tried the code line form the post above. Let's see if that helps.
just did it. and thanks @Andreas_Hegenberg
i might add i am thru setapp on 3.553 | 1693 on macbook pro 2019 16" . i might get a direct license in the future if need be. i love this app and is probably the only app that has kept me from going back to windows. well, there are other great apps too but this is sort of the bedrock app for me. idk why but it just is. <3
machine info:
OS: big sur 11.4 (20F71)
MacBook Pro (16-inch, 2019)
2.6 GHz 6-Core Intel Core i7
16 GB 2667 MHz DDR4
512GB SSD
Intel UHD Graphics 630 1536 MB
i dont know much about logs and the console but i googled it and this is what i found on my computer. hope im not exposing sensitive info but i will copy and paste here?
in system.log i found this when i searched the term "bettertouchtool" also , this is AFTER i update the code as aforementioned above:
Jun 13 13:25:38 MacintoshPro16 com.apple.xpc.launchd[1] (application.com.hegenberg.bettertouchtool-setapp.47118277.47118289[7192]): Service exited due to SIGTERM | sent by BTTRelaunch[7252]
Jun 13 13:25:38 MacintoshPro16 com.apple.xpc.launchd[1]: Coalition Cache Hit: app<application.com.hegenberg.bettertouchtool-setapp.47118277.47118289(501)> [1080]
Jun 13 13:25:42 MacintoshPro16 com.apple.xpc.launchd[1] (application.com.hegenberg.BTTRelaunch.47118530.47121353[7252]): Service exited due to SIGTERM | sent by BetterTouchTool[56817]
Jun 13 16:26:05 MacintoshPro16 com.apple.xpc.launchd[1] (application.com.hegenberg.BTTRelaunch.47118530.47121353[56847]): Service exited due to SIGTERM | sent by BetterTouchTool[56817]
Jun 13 16:27:45 MacintoshPro16 com.apple.xpc.launchd[1]: Coalition Cache Hit: app<application.com.hegenberg.bettertouchtool-setapp.47118277.47118289(501)> [1080]
as for log reports, it says a date of June 05 2021 but when i reveal the log in Finder, it has a date of today, which is June 13 2021. i will copy and paste below and if i can attach it as a file , i will try that too
2021-06-05 09:53:50.243 BetterTouchProcessPrioWatcher[116:830] launching
2021-06-05 09:53:50.265 BetterTouchProcessPrioWatcher[116:830] did launch
2021-06-05 10:01:00.128 BetterTouchProcessPrioWatcher[116:830] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-05 10:01:02.041 BetterTouchProcessPrioWatcher[116:830] did set BetterTouchTool priority to -2 | 0
2021-06-05 10:01:03.786 BetterTouchProcessPrioWatcher[116:830] BTT did launch
2021-06-05 15:05:31.300 BetterTouchProcessPrioWatcher[116:830] BTT did launch
2021-06-05 15:05:31.302 BetterTouchProcessPrioWatcher[116:830] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-05 15:05:33.119 BetterTouchProcessPrioWatcher[116:830] did set BetterTouchTool priority to -2 | 0
2021-06-05 18:31:38.879 BetterTouchProcessPrioWatcher[116:830] BTT did launch
2021-06-05 18:31:38.881 BetterTouchProcessPrioWatcher[116:830] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-05 18:31:39.912 BetterTouchProcessPrioWatcher[116:830] did set BetterTouchTool priority to -2 | 0
2021-06-05 20:24:54.045 BetterTouchProcessPrioWatcher[116:830] BTT did launch
2021-06-05 20:24:54.046 BetterTouchProcessPrioWatcher[116:830] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-05 20:24:55.055 BetterTouchProcessPrioWatcher[116:830] did set BetterTouchTool priority to -2 | 0
2021-06-06 05:01:02.531 BetterTouchProcessPrioWatcher[116:830] BTT did launch
2021-06-06 05:01:02.533 BetterTouchProcessPrioWatcher[116:830] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-06 05:01:04.096 BetterTouchProcessPrioWatcher[116:830] did set BetterTouchTool priority to -2 | 0
2021-06-06 06:08:02.352 BetterTouchProcessPrioWatcher[116:830] BTT did launch
2021-06-06 06:08:02.354 BetterTouchProcessPrioWatcher[116:830] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-06 06:08:03.390 BetterTouchProcessPrioWatcher[116:830] did set BetterTouchTool priority to -2 | 0
2021-06-06 06:15:33.883 BetterTouchProcessPrioWatcher[116:830] BTT did launch
2021-06-06 06:15:33.884 BetterTouchProcessPrioWatcher[116:830] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-06 06:15:34.816 BetterTouchProcessPrioWatcher[116:830] did set BetterTouchTool priority to -2 | 0
2021-06-06 08:19:53.126 BetterTouchProcessPrioWatcher[116:830] BTT did launch
2021-06-06 08:19:53.130 BetterTouchProcessPrioWatcher[116:830] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-06 08:19:55.710 BetterTouchProcessPrioWatcher[116:830] did set BetterTouchTool priority to -2 | 0
2021-06-06 08:19:55.896 BetterTouchProcessPrioWatcher[117:839] launching
2021-06-06 08:19:55.919 BetterTouchProcessPrioWatcher[117:839] did launch
2021-06-06 08:58:48.542 BetterTouchProcessPrioWatcher[117:839] BTT did launch
2021-06-06 08:58:48.545 BetterTouchProcessPrioWatcher[117:839] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-06 08:58:52.227 BetterTouchProcessPrioWatcher[117:839] did set BetterTouchTool priority to -2 | 0
2021-06-06 10:29:56.772 BetterTouchProcessPrioWatcher[117:839] BTT did launch
2021-06-06 10:29:56.774 BetterTouchProcessPrioWatcher[117:839] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-06 10:29:57.819 BetterTouchProcessPrioWatcher[117:839] did set BetterTouchTool priority to -2 | 0
2021-06-06 17:46:48.973 BetterTouchProcessPrioWatcher[117:839] BTT did launch
2021-06-06 17:46:48.975 BetterTouchProcessPrioWatcher[117:839] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-06 17:46:50.258 BetterTouchProcessPrioWatcher[117:839] did set BetterTouchTool priority to -2 | 0
2021-06-06 18:06:02.443 BetterTouchProcessPrioWatcher[117:839] BTT did launch
2021-06-06 18:06:02.445 BetterTouchProcessPrioWatcher[117:839] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-06 18:06:03.320 BetterTouchProcessPrioWatcher[117:839] did set BetterTouchTool priority to -2 | 0
2021-06-06 18:26:33.932 BetterTouchProcessPrioWatcher[117:839] BTT did launch
2021-06-06 18:26:33.933 BetterTouchProcessPrioWatcher[117:839] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-06 18:26:36.162 BetterTouchProcessPrioWatcher[117:839] did set BetterTouchTool priority to -2 | 0
2021-06-06 19:17:42.542 BetterTouchProcessPrioWatcher[117:839] BTT did launch
2021-06-06 19:17:42.544 BetterTouchProcessPrioWatcher[117:839] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-06 19:17:43.485 BetterTouchProcessPrioWatcher[117:839] did set BetterTouchTool priority to -2 | 0
2021-06-06 19:35:12.067 BetterTouchProcessPrioWatcher[117:839] BTT did launch
2021-06-06 19:35:12.068 BetterTouchProcessPrioWatcher[117:839] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-06 19:35:13.005 BetterTouchProcessPrioWatcher[117:839] did set BetterTouchTool priority to -2 | 0
2021-06-07 04:17:45.360 BetterTouchProcessPrioWatcher[117:839] BTT did launch
2021-06-07 04:17:45.361 BetterTouchProcessPrioWatcher[117:839] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-07 04:17:46.359 BetterTouchProcessPrioWatcher[117:839] did set BetterTouchTool priority to -2 | 0
2021-06-07 06:18:19.117 BetterTouchProcessPrioWatcher[117:839] BTT did launch
2021-06-07 06:18:19.119 BetterTouchProcessPrioWatcher[117:839] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-07 06:18:20.323 BetterTouchProcessPrioWatcher[117:839] did set BetterTouchTool priority to -2 | 0
2021-06-07 08:18:32.004 BetterTouchProcessPrioWatcher[117:839] BTT did launch
2021-06-07 08:18:32.006 BetterTouchProcessPrioWatcher[117:839] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-07 08:18:37.483 BetterTouchProcessPrioWatcher[117:839] did set BetterTouchTool priority to -2 | 0
2021-06-07 18:29:29.499 BetterTouchProcessPrioWatcher[117:839] BTT did launch
2021-06-07 18:29:29.500 BetterTouchProcessPrioWatcher[117:839] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-07 18:29:30.657 BetterTouchProcessPrioWatcher[117:839] did set BetterTouchTool priority to -2 | 0
2021-06-07 18:53:00.157 BetterTouchProcessPrioWatcher[117:836] launching
2021-06-07 18:53:00.179 BetterTouchProcessPrioWatcher[117:836] did launch
2021-06-07 18:53:43.767 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-07 18:53:43.769 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-07 18:53:45.842 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-08 03:42:23.457 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-08 03:42:23.461 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-08 03:42:26.062 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-08 06:34:05.692 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-08 06:34:05.693 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-08 06:34:06.774 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-08 07:04:09.082 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-08 07:04:10.192 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-08 07:04:10.192 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-08 07:19:11.686 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-08 07:19:11.687 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-08 07:19:12.757 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-08 09:21:21.689 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-08 09:21:21.690 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-08 09:21:22.783 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-08 10:34:14.725 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-08 10:34:14.726 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-08 10:34:15.800 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-08 16:49:40.604 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-08 16:49:40.606 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-08 16:49:45.141 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-08 20:03:18.197 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-08 20:03:18.198 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-08 20:03:19.555 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-09 05:25:12.027 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-09 05:25:12.028 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-09 05:25:13.358 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-09 07:15:37.144 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-09 07:15:37.146 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-09 07:15:39.419 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-09 08:55:41.160 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-09 08:55:41.161 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-09 08:55:42.537 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-09 14:35:42.681 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-09 14:35:42.683 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-09 14:35:44.251 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-09 15:23:53.200 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-09 15:23:53.202 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-09 15:23:54.555 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-09 15:30:41.619 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-09 15:30:41.620 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-09 15:30:43.197 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-09 17:54:33.494 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-09 17:54:33.495 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-09 17:54:34.683 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-09 18:09:35.663 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-09 18:09:35.664 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-09 18:09:36.898 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-09 18:24:38.509 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-09 18:24:38.511 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-09 18:24:39.667 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-09 18:39:40.605 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-09 18:39:40.606 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-09 18:39:41.821 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-09 18:54:43.506 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-09 18:54:43.507 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-09 18:54:44.681 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-09 18:56:51.415 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-09 18:56:51.417 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-09 18:56:52.764 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-09 19:44:17.726 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-09 19:44:17.728 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-09 19:44:18.888 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-09 20:09:20.704 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-09 20:09:20.706 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-09 20:09:21.888 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-09 21:58:29.448 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-09 21:58:29.450 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-09 21:58:31.874 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-10 01:28:50.069 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-10 01:28:50.071 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-10 01:28:51.640 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-10 01:33:23.526 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-10 01:33:23.527 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-10 01:33:24.855 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-10 07:15:27.304 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-10 07:15:27.308 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-10 07:15:30.289 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-10 07:42:55.489 BetterTouchProcessPrioWatcher[117:836] BTT did launch
2021-06-10 07:42:55.492 BetterTouchProcessPrioWatcher[117:836] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-10 07:42:57.512 BetterTouchProcessPrioWatcher[117:836] did set BetterTouchTool priority to -2 | 0
2021-06-10 07:43:14.591 BetterTouchProcessPrioWatcher[117:837] launching
2021-06-10 07:43:14.621 BetterTouchProcessPrioWatcher[117:837] did launch
2021-06-10 10:21:42.469 BetterTouchProcessPrioWatcher[117:837] BTT did launch
2021-06-10 10:21:42.471 BetterTouchProcessPrioWatcher[117:837] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-10 10:21:44.179 BetterTouchProcessPrioWatcher[117:837] did set BetterTouchTool priority to -2 | 0
2021-06-10 17:24:57.453 BetterTouchProcessPrioWatcher[117:837] BTT did launch
2021-06-10 17:24:57.455 BetterTouchProcessPrioWatcher[117:837] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-10 17:24:58.520 BetterTouchProcessPrioWatcher[117:837] did set BetterTouchTool priority to -2 | 0
2021-06-10 21:33:43.028 BetterTouchProcessPrioWatcher[117:837] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-10 21:33:46.711 BetterTouchProcessPrioWatcher[117:837] did set BetterTouchTool priority to -2 | 0
2021-06-10 21:33:46.727 BetterTouchProcessPrioWatcher[117:837] BTT did launch
2021-06-11 08:24:51.929 BetterTouchProcessPrioWatcher[117:837] BTT did launch
2021-06-11 08:24:51.931 BetterTouchProcessPrioWatcher[117:837] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-11 08:24:53.381 BetterTouchProcessPrioWatcher[117:837] did set BetterTouchTool priority to -2 | 0
2021-06-11 08:29:54.670 BetterTouchProcessPrioWatcher[117:837] BTT did launch
2021-06-11 08:29:54.672 BetterTouchProcessPrioWatcher[117:837] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-11 08:29:55.434 BetterTouchProcessPrioWatcher[117:837] did set BetterTouchTool priority to -2 | 0
2021-06-11 08:32:41.161 BetterTouchProcessPrioWatcher[117:837] BTT did launch
2021-06-11 08:32:41.162 BetterTouchProcessPrioWatcher[117:837] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-11 08:32:42.068 BetterTouchProcessPrioWatcher[117:837] did set BetterTouchTool priority to -2 | 0
2021-06-11 19:50:02.057 BetterTouchProcessPrioWatcher[117:837] BTT did launch
2021-06-11 19:50:02.058 BetterTouchProcessPrioWatcher[117:837] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-11 19:50:03.539 BetterTouchProcessPrioWatcher[117:837] did set BetterTouchTool priority to -2 | 0
2021-06-11 20:07:16.454 BetterTouchProcessPrioWatcher[117:837] BTT did launch
2021-06-11 20:07:16.456 BetterTouchProcessPrioWatcher[117:837] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-11 20:07:17.546 BetterTouchProcessPrioWatcher[117:837] did set BetterTouchTool priority to -2 | 0
2021-06-12 03:32:01.375 BetterTouchProcessPrioWatcher[117:837] BTT did launch
2021-06-12 03:32:01.377 BetterTouchProcessPrioWatcher[117:837] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-12 03:32:02.624 BetterTouchProcessPrioWatcher[117:837] did set BetterTouchTool priority to -2 | 0
2021-06-12 05:34:23.071 BetterTouchProcessPrioWatcher[117:837] BTT did launch
2021-06-12 05:34:23.075 BetterTouchProcessPrioWatcher[117:837] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-12 05:34:24.004 BetterTouchProcessPrioWatcher[117:837] did set BetterTouchTool priority to -2 | 0
2021-06-12 07:34:40.070 BetterTouchProcessPrioWatcher[117:837] BTT did launch
2021-06-12 07:34:40.071 BetterTouchProcessPrioWatcher[117:837] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-12 07:34:41.391 BetterTouchProcessPrioWatcher[117:837] did set BetterTouchTool priority to -2 | 0
2021-06-12 08:34:22.451 BetterTouchProcessPrioWatcher[117:837] BTT did launch
2021-06-12 08:34:22.454 BetterTouchProcessPrioWatcher[117:837] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-12 08:34:23.883 BetterTouchProcessPrioWatcher[117:837] did set BetterTouchTool priority to -2 | 0
2021-06-13 13:25:42.588 BetterTouchProcessPrioWatcher[117:837] BTT did launch
2021-06-13 13:25:42.591 BetterTouchProcessPrioWatcher[117:837] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-13 13:25:44.061 BetterTouchProcessPrioWatcher[117:837] did set BetterTouchTool priority to -2 | 0
2021-06-13 16:27:47.084 BetterTouchProcessPrioWatcher[117:837] BTT did launch
2021-06-13 16:27:47.086 BetterTouchProcessPrioWatcher[117:837] checking signature for bundle: file:///Applications/Setapp/BetterTouchTool.app/
2021-06-13 16:27:48.136 BetterTouchProcessPrioWatcher[117:837] did set BetterTouchTool priority to -2 | 0
it wont let me upload a .log file but i will share a link to a copy of it via dropbox:
