Keep system haptic response for more than 3 finger click on trackpad
Currently It seems BTT would always override system haptic response from 4 finger click and above. Is It possible to just keep system click response all the time? It also seems configuring any trackpad gestures would trigger these override even while only configuring swipe gestures.
unfortunately that would cause lots of weird behavior right now, you can however adjust the values in the advanced settings:
I'll check again soon whether anything in the available API's has changed to allow for a better handling of this.
