Java Script Transformer not working for me
Sonoma 14.1.1 (23B81)
I had a few transformers working but my recent upgrade to the latest paid version has broken my scripts. Now even the stock example script doesn't seem to work.
"paste specific items" and "Transform clipboard contents with Java Script" are both not working for me.
Other triggers and actions are working - I can replace the transformer with e.g. Send Keyboard "T" - that works
Which version of BTT are you currently on? There was a fix related to the "Paste specific item" action in the very latest 4.9999
I am using the very latest version 4.9999.
What steps could I take to fix this?
Can I suggest that If it’s working your end, can you give details on what steps you took. I’ll do the exact same steps and see what’s results I get.
could you try whether they work for you when you invoke them from the clipboard manager directly?
If so, do they keep working afterwards?
No, invoking the java script transformer from the clipboard manager didn't do anything either.
HOWEVER... I've managed to get it working again, although I haven't changed any of the general settings or java script code or settings within the shortcut etc.
I exported the transformers I had, deleted them, made a fresh one and got that working. Simply reimporting them didn't work without that last step didn't work.
So, I don't really know what happened. Perhaps a setting got corrupted?
The only other thing I did was to change the order of the transformers, so that might have been a contributing factor.
weird - in that case I think it might start happening again.
I will look into the issue soon!
This is somewhat broken now for me too after updating to the latest version.
The keyboard shortcut alone does not work anymore. But, if you open up the clipboard manager first before running the keyboard shortcut, it does work oddly enough.
It also works to run it directly by pressing the button in clipboard manager.
I even recreated the shortcut and the transformer to no avail.
There is also a separate minor bug that occurs if you create a named transformer and then delete it. It still shows up in the drop down list of transformers in the "Paste Items" action. Restarting BTT doesn't help.
could you check whether this works in 5.174 alpha (uploading now). I completely reworked the paste functionality just now
Thanks. After further testing, the problem seems to be intermittent, where it works occasionally and not other times. I am using HyperKey shortcut.
But, I would say it always reliably worked after opening the clipboard manager and then using the keyboard shortcut.
I will give alpha a try.
Yep would be great. If the approach used in the newer builds works it will also make the pasting faster.
Whatever you did, I love it. It works perfectly now and HyperKey is also working every time as well. (In the past, Hyperkey shortcuts often needed a couple of presses to work.)
Thank you very much!
