Hi together,
So, I discovered recently that Apple Script was able to trigger the sound volume specific to iTunes. Thought that this would be super useful if you often play music via AirPlay bla bla, whatever, so I tried to make an Apple Script Slider controlling the iTunes Volume.
My problem is that the little guy gets the sound volume and returns it properly, but he is unable to tell iTunes to set it
Help is welcome (and kinda wanted ).
if application "iTunes" is running then
tell application "iTunes"
set itunesvolume to sound volume
end tell
set currentvolume to itunesvolume / 100
return currentvolume
else
return ""
end if
But how do I manage to tell the slider he should also tell iTunes to change the volume?
Thanks a lot for your help, have a great day everybody!
