Issues after upgrading to Sequoia
hey there,
After upgrading to macOS sequoia my keyboard shortcuts to "maximize", "left half" and "right half" stopped working. I have tried resetting them and restarting the app and they still dont work. The left third, right third and center third shortcuts work fine though, so there is something specifically about the other actions that is broken. I'm using BST 1.9.12
do you have „displays have separate spaces“ disabled in system settings? If so, make sure to set BetterSnapTool to use the classic snapping mode (at the top of the general settings screen)
Yes indeed I had it on and switching to classic snapping mode fixed it. Many thanks!
