Issue with triggering similar key sequences
Hi @Andreas_Hegenberg . I'm trying to setup trigger via key sequences.
I have a key sequence on right ⌥ which does actionA. I want another key sequence which does actionB on pressing right ⌥ twice. I tried the below but when pressing the right ⌥ twice, it only do actionA. How to fix this?
both of them are doing an action which is actually working. So there's nothing wrong with the action. Action here is to open a specific app.
use the slider „trigger only if no further keyboard input is detected for x seconds“ (on the single press sequence)
