I have an issue with the Command+Shift+W (snapping grid). The problem is that I'm French and my keyboard is AZERTY. Thus for me, the shortcut becomes Command+Shift+Z which often conflicts with other app shortcuts (most of the time it's the shortcut to revert an 'undo' action).
So basically, everytime I update GC-BTT, I have to manually edit the shortcut.
It's not really a problem but I wonder if there would be a way to change this so that the shortcut uses the actual character and not the position of the key on the keyboard...
Thanks a lot.
