Issue with keyboard shortcuts not being recognized
Note:
This has been happening for around 3 - 6 months
For the last 3 - 6 months, my keyboard shortcuts often wont be recognized. I have to go into the app and click configure to bring the page up, then it registers them.
I never had this issue previously.
Is there anything I can try? I did try using the elevated keyboard but it didnt fix it and it caused me other issues (It was a couple months ago so I can't actually remember what the issue was)
keyboard
  • Type of Mac: Mac Pro
  • macOS version: 27.2.1
  • BetterTouchTool version: 6.1117
maybe some app is enabling secure input? (BTT would show a warning in its menubar status menu.
What are your shortcuts doing and what kind of shortcuts are they?
The only warnings I have are for slow window snapping on a couple of apps.
The shortcuts are to control Mac Shortcuts and send terminal commands such as "curl -s http://192.168.1.202/relay/0?turn=off" - I use them to turn smart outlets on and off etc and control devices power states in my workplace.
are they normal shortcuts or do they include some special ones like F1-12?
So I have Caps Lock bound to right Ctrl button and I'm mainly using that to trigger them (as in in better touch tool select the separate modifier option)
I've tried just using right Ctrl and that doesn't launch them either though.
So it's right ctrl + 1, + 2 etc. for diff shortcuts
when this happens, does it recognize shortcuts based on left-ctrl?
If you can reproduce the issue, do that, then go to Help -> Export Basic Debug Logs and send them to me (andreas@folivora.ai)
Maybe I can see what’s wrong.
It just did it as I went to it to try. I managed to get the logs for you and email them. In this case I tried pressing Caps + 5 multiple times and it didn't register. I then opened BTT and it didnt register. I then clicked on BTT to bring it into focus and then it worked.
I don't have anything bound to left Ctrl so I wasn't able to try it but I'll bind something now and try it again next time it doesn't work
