Issue with basic function
This should cmd+tab right? What am I missing?
I'm trying to give myself the ability to cmd+tab through windows with three finger swipe. This is what I have set up currently. As far as I can tell this should work, but it doesn't.
Is it an Option for you to use the BTT Window Switcher (see action: "Show Window Switcher For All Open Apps") to solve your UseCase? It is easy to integrate with such Continuous Swipe Gestures.
This is how I've set it up:
if you want the system app switcher, I'd recommend to use BTT's "Application Switcher" action with gesture mode enabled:
Thank you Volker. This is what I was trying to do.
Hi Andreas. The application switcher looks like a nice option. But to help complete my understanding I still would like to know why the gesture I posted doesn't work.
I have been liking using Better Touch Tool and will likely purchase a license.
