I've set up the "3 Finger Tap" trackpad trigger to the "Middle Click" action for "All Apps". I use it to open link in a new tab in Chrome.
It works OK, however the trigger only occurs if I move the cursor after doing the 3-finger tap. If I just do the tap then nothing happens.
In other words:
- Just do the 3-fingers tap: nothing happens, the link doesn't open in new tab.
- Do the 3-finger tap then move the cursor on the trackpad: triggers correctly and link opens in new tab.
Are you able to confirm this bug?
**Affected input device:
MacBook Trackpad
- Type of Mac: MBP
- macOS version: 11.5.1
- BetterTouchTool version: 3.570
