Issue: Frontmost Windows Side By Side
I use (not very often) the "Frontmost Windows in Quarters" and "Frontmost Windows Side By Side" actions.
The "Frontmost Windows in Quarters" is working as expected.
But the actions "Frontmost Windows Side By Side (First Left)" and "Frontmost Windows Side By Side (First Right)" are not working as expected.
Both actions (First Left & First Right) are moving and resizing the first window correctly, but the second window is not moved and not resized.
Tested with 2 and more windows in Finder and TextEdit.
BTT 6.978
macOS 15.8.1
Mh they have been working fine here for years (I think even on macOS 15)
However in your recent video about the virtual side screens, you had this translucent overlay appear that didn't belong to the virtual side screen feature. I think such translucent windows could prevent this from working correctly. Maybe that is the issue?
I don't know where that translucent window could come from (if it is from BTT the only thing I can think of is a floating menu without content or a broken floating webview). It could however also come from some other app.
//edit: 6.979 skips translucent windows, maybe that will help
Running BTT 6,978:
I found that the translucent window that was appearing in the side screen was the window of HazeOver.
Also this window from HazeOver was interacing with the "Frontmost Windows Side By Side" action, causing the issue I posted.
Interestingly, this HazeOver window is NOT interacing with the "Frontmost Windows in Quarters" action, causing no issues.
Closing HazeOver app fixes all the issues of the side screen (it fixes the double click issue and the phantom translucent window) and also the issue of the "Frontmost Windows Side By Side".
Running BTT 6,979:
It has fixed the issue of the "Frontmost Windows Side By Side" with HazeOver. Great!
Could you apply this solution also for the side screen?
Remarks:
The "Frontmost Windows Side By Side" action only resizes and moves the first two windows of the frontmost app. I mean that the rest of opened windows (3rd,4th,etc) are not moved and not resized. Is this by design?
This is the opposite behaviour to "Frontmost Windows in Quarters" action, wich moves and resizes the first four windows, but also the 5th, the 6th, etc.
I guess this problem with HazeOver is occuring after I updated it to the last version some days ago. I remember the release notes said that it was updated for macOS 27. Since HazeOver is a fairly widely used app, it might be a good idea to implement a global solution in BTT to avoid conflicts with this HazeOver window.
ah, that sounds like a bug in HazeOver then. BTT can only apply some workarounds, but as this will affect tons of other things as well, it would be much better if HazeOver applied a fix to exclude that window from Accessibility
yeah, that makes sense.
I will contact them for this issue now.
I will tell you what they say.
Thanks.
Did you notice this? Is it correct this behaviour compared to the "Frontmost Windows in Quarters" action?
I am not sure whether I understand, the side by side one takes the first two windows, the quarters one takes the first four windows - regardless of app (at least that’s how it should be)
Scenario 1:
  • There are 5 small Finder windows in the center of the screen
  • I trigger the "Frontmost Windows Side By Side" action
  • The first two windows are moved and resized
  • The other three windows remains small in the center of the screen
Scenario 2:
  • I trigger the "Frontmost Windows in Quarters" action
  • The five windows are moved and resized in quarters
IMO, it is a different behaviour:
"Frontmost Windows in Quarters" affects all opened windows (not only the first four)
"Frontmost Windows Side By Side" affects only the first two windows (the rest are excluded)
I would prefer that the "Frontmost Windows Side By Side" affects all opened windows, but maybe it makes more sense as it is now.
I have thought that could be handy to add a dropdown menu to configure the behaviour of both actions.
For "Frontmost Windows Side By Side" action:
option1 - only move and resize the first two windows
option2 - move and resize all windows
For "Frontmost Windows in Quarters" action:
option1 - only move and resize the first four windows
I don’t think this behavior you describe exists :grimacing: at least not here. The quarters action also only uses the frontmost 4 windows
You're right, I got mixed up. In the tests I ran with 5 Finder windows, the fifth window was already positioned in one of the quadrants. That’s what threw me off. Sorry for the trouble! :grinning_face_with_smiling_eyes:
anyways I could add an option to position any configurable number of frontmost windows. Might be a good idea.
Absolutely, that would be really useful (at least for me!) :grinning_face:
Yesterday I was thinking about a new action: a "smart window resizer."
I’ve posted it as a feature request.
Hi, HazeOver developer here. The next update will hide its dimming windows from Accessibility. Thank you @Andreas_Hegenberg for pointing that out, good call.
On the BTT side, I’d suggest using NSWindow.windowNumber(at:belowWindowWithWindowNumber: 0) for the window under the pointer. It returns the window a click would hit and skips click-through windows, so there's no need for an app list or a translucency check. Note that the desktop window has a negative window level, and the call returns 0 until NSApplication.shared exists. AXUIElementCopyElementAtPosition skips the dimming windows too.
great!
BTT uses that method where possible, but it can not be applied to all scenarios, often the only way is through Accessibility - especially if (as discussed here) not the window under the cursor is targeted
