Currently what i end up doing is making a new config preset and then making the triggers again with the new preset as the default. This is kind of annoying because i like to export each set of triggers as their own config.
Thanks for any help!
either copy & paste into the new preset or use presets -> move selected triggers to preset (from the menubar menu)
Ahhhh sweet. I always forget to check the menubar menu.
