I'm activating a ChatGPT floating menu from the Shortcuts and pasting text with a prompt. How can I make the next action either be clicking the enter button or simulating the keyboard shortcut command-return? My action sequence is in the Shortcuts app, so I'm looking for a way to do it there. The "find image on screen" shortcut action always crashes BTT.
Does that work with a floating window displaying ChatGPT ? In other words we use Send keyboard shortcut to Focused App while on a website in a floating menu to, say, press enter onto submit a form?
That worked! Thanks @Andreas_Hegenberg . You legend ![]()
