I want to use my keys ö and ä for (+) and (-) to increase exposure in Lightroom. Nevertheless if I assign a hotkey W for white balance to my (-) keyboard key, when pressing ä lightroom throws w.
Is there a way to disable the lightroom default hotkey commands?
Thanks for any help
In reality than A triggered C, but I wanted that A to trigger B instead. The problem occurs if a key is one time used as trigger and another time as action.
If I tick "Prevent recursive triggers" for the command A triggers B, it solves the problem
Nevertheless another problem occurs, namely, that "repeat assigned action" does not work if I select "prevent recursive triggers"
@LukasB Exactly, this has been known for a long time and will hopefully be fixed soon.
Until it is so far, I know only one workaround. Look for a combination of characters that give the same result but are not recognized as recursive by BTT.
a = a is recursive.
a = fn a is not recursive and can be repeated.
Depending on the app and the character to be repeated, there are different possibilities. I think by now I know them all, I need this so often
