I want two 3 finger swipe between recently opened apps... is it possible?
Yes exactly, but not for full screen apps, but any app
okay. I have a way of doing this, but it acts the same as pressing Alt + Tab
. this means it will only work between two tabs at a time.
Disable the three-finger swipe in System Preferences, then do this:
Command + 3
- make a new gesture using Three Finger Swipe right.
- Set it to do keyboard shortcut
Command + Tab
Thanks, I will try it! I hope developers can add a better app switch mechanism
