is it possible to switch to fullscreen desktop/space for mission control?
guys i have 4 desktops/spaces in mission control and i use better touch tool with screen hot corners to quickly switch between these 4 desktops in mission control
but if some application is opened in fullscreen it acts as 5th desktop in mission control
so the question is - in better touchtool is there a way to setup - if i touch defined hotcorner of screen then mission control jumps to 5th desktop (the one which has fullscreen application) (similar how there is a feature to jump to any of my 4 mission control desktops/spaces)
MacOS has a shortcut for moving directly to a space number. Just setup this shortcut in BTT to one of the hot corners should do the job.
thanks man but unfortunately theres no shortcut to switch to desktop which has fullscreen appication
check this out
shortcuts work on desktop 1/2/3/4 but i cant switch to desktop named VNC viewer ( i guess its not a desktop by definition - cuz its fullscreen app) but still it shows up as desktop
and theres only these shortcuts for it - so no option to switch to fullscreen app
Oh sorry, i thought this also works for full screen apps. I apologize.
Is it always the same app you are putting to full screen?
i guess it is currently the same app all the time, but eventualy maybe i would switch it up
but actualy i found a clue - theres a conditon parameter for active space ID like this bellow
so maybe you guys could add an action which would also have this ID
thus - if i hot corner - then switch to active_space=6
or maybe there already is one?
