Is it possible to have a navigation history?
@Andreas_Hegenberg Let's say the BTT configuration window is set to “All Apps” in the ‘Shortcuts’ section. Now I switch to the Safari app “Key Sequences”.
Going back works the same way—click here, click there.
How about having a “history” for each step? For example, two arrows like in any browser?
I have thought about this in the past, but it is pretty complex to integrate into the existing UI. I have a list with some items that I will tackle with the next bigger UI work, I'll add that to it - at least to check feasibility.
Ok, thanks. Can you estimate how much longer BTT will remain compatible with Ventura? Or will it be the case that BTT will still run, but not all features will be available?
The main reason I want to stay on Ventura as long as possible is that, apparently, there’s no way to accelerate the trackpad on newer operating systems.
I believe you told me that even BTT won’t be able to do that. Maybe you’ll find a way :slight_smile:
I think BTT will continue to work for at least 2 more years on macOS 13 (currently it still supports macOS 11). However new features will become more and more limited and I usually don't test on older macOS versions. Unfortunately Apple never makes new API available on older macOS, so lots of stuff is not possible on older macOS. (For example BTT's dictation support can not work on macOS 13)
