is it possible to display (ideally toggle) a floating window containing text in rich text (rtfd) format with images
This would allow me to consult detailed technical notes containing text and images while I am working in other apps.
thanks in advance for your time and help
Why not using the excellent BTT Snippet Manager? It floats, you can toggle and it's easy to display text and images.
i don’t have a rtfd view for floating menus yet, but I think it’s a good idea to add one and also add a generic quicklook file view. Should be easy to add
The excellent CleanShot screenshot utility (highly recommended by me, fwiw) includes the ability to pin screenshots to the screen. I use the pin function regularly to accomplish what you want.
You can make your own screenshots (useful for pages in long PDFs), or open JPGs or PNGs and I suspect other image formats.
For this I use BTT's clipboard manager, it can pin screenshots (and select text from them) but also scrollable/zoomable pdfs etc.
I will look. thank you very much @Andreas_Hegenberg
thank you but the issue is to toggle
is there a way to toggle (on when you need them and off when you are finished). thank you
I was not aware and will look at the documentation. Thank you @Frank1 !
you mean the clipboard manager ? My problem is that I find very little documentation
Do I have to "turn on" the clipboard manager somewhere ? I am totally confused as to how even to start. thank you !
I can send text or images to the clipboard manager but not both, which is essential.
Is it my configuration or is text and images in the same clip not possible ?
thank you @Andreas_Hegenberg
if you copy from a rtfd it should show up fine with images and text
