Can't open a selected group to edit it in a created group
Affected input device:
Macbook Pro 13" 2020
- Type of Mac: Macbook Pro 13" 2020
- macOS version: macOS Monterey 12.4
- BetterTouchTool version: 3.786
Preconditions:
I have a Group 1 with Group 2 inside
When I'm in Group 1, I want to edit Group 2
When I'm clicking on a Group 2 a window with Group 1 is opened, so I can't configure Group 2
Actual result:
Group 1 is opening when I'm clicking to edit internal Group 2
Expected result:
Group 2 is opened for configuring when I clicked on it
Video:
BetterTouchTool does not yet support subfolders.
I think you might have gotten it by copy & paste, correct? I should prevent that for now.
Thanks for the answer, I didn't copy paste anything, just had a possibility to create a subfolder inside
Any info when subfolders feature will be released?
oh you are right, it shows up in the menu. Looks like a recent regression.
Subfolders for Touch Bar are currently not planned. You can workaround it by using the predefined action "Open Touch Bar Group With Name", but the group itself needs to be defined at top level. (It can be disabled & hidden though)
Thanks a lot! Will try that, great app to use (got a Macbook with touch bar a few days ago), definitely will buy your app, love it <3
