Inaccurate click after enabling Magic Mouse TouchPad feature
Inaccurate click after enabling Magic Mouse TouchPad feature. Every time I click, cursor moves randomly few inches.
Magic Mouse
  • Type of Mac: Mojave
  • macOS version: 10.14.3
  • BetterTouchTool version: 2.7.17
That's expected and can not be prevented due to the limited sensors of the Magic Mouse, you should use tap to click instead of actually pressing down the mouse.
Appreciate the quick response and accurate workaround.
