I have a ton of calendars, one for each client, with names like "Work - JT" and "Work - AW." Considering the number of widgets in @GoldenChaos into which I have to enter the names, it would be helpful if I could refer to them all with something like "Work - *", rather than having to update each widget's information whenever I get a new client.
The latest version now supports wildcards *
Awesome! Thank you!
