Hi, I hope someone can help. About 2 or 3 weeks ago Illustrator and Photoshop stopped snapping correctly. It won't snap on any side. I have reinstalled both Apps with no luck.
I have a MacBook running Ventura 13.5.2 (22G91)
I am using Version 1.9.9 and uninstalled and redownloaded but with no luck still.
Ahh ok. Thanks so much for taking the time to let me know. It's odd because InDesign, After Effects and Acrobat, which I use regularly, are still working ok. I will reach out to Adobe to raise the issue. Is there anything I should specifically say? Do you think they are aware of your App and the issues relating to snapping?
It's affecting all window management apps on macOS as far as I know they are aware of the issue. Currently Photoshop and Illustrator are affected as far as I know. Probably InDesign / Aftereffects / Acrobat haven't received an update.
