Icons are not working for dark mode in Floating menus
I added the icon for floating menu in dark mode but it does not show any icon even though macbook is running dark mode too.
I dont get any icon in floating menu**
  • Type of Mac: Macbook
  • macOS version: Version 15.7.7
  • BetterTouchTool version: 6.521
you have set both, a sf symbol name and a image file. Maybe because they were both listed when filtering for icon.
Re-selecting "From Image File" should work:
I added an image from Clipboard in "From Image File"
And removed any symbol name from "From SF Symbols"
Icon is not showing in Floating Menu.
If I add a icon from SF symbols - It works but no icon would be displayed if I add image from clipboard in "From Image file"
